[postgis-users] Returning polygons if any of a polygon input points lie in the polygons
Hugues François
hugues.francois at irstea.fr
Tue Nov 18 07:52:05 PST 2014
I think ST_Intersects will meet your needs :
SELECT zone,gid,state,name,ST_Asgeojson( geom )
FROM polys
WHERE ST_Intersects(ST_GeomFromText('POLYGON((-109 42,-108 42, -108 43; -109 43, -109 42))', 4269), geom)
Hugues.
Hugues François
Tourisme et systèmes d’information
Irstea – DTM
+33 (0)4.76.76.27.44
+33 (0)6.77.66.21.31
De : postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] De la part de Joseph Spenner
Envoyé : mardi 18 novembre 2014 16:44
À : PostGIS Users Discussion
Objet : Re: [postgis-users] Returning polygons if any of a polygon input points lie in the polygons
Something I did notice though-- it seems that if the input polygon completely surrounds a polygon stored in my database, it is not included in the result. I read something about this here: http://postgis.net/docs/ST_Overlaps.html
"Returns TRUE if the Geometries "spatially overlap". By that we mean they intersect, but one does not completely contain another."
I do need the polygons which are completely contained as well. Can this be done?
Thanks again for the help. I'm getting there!
Regards,
Joseph Spenner
To: Rémi Cura <remi.cura at gmail.com>; PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Sent: Tuesday, November 18, 2014 8:35 AM
Subject: Re: [postgis-users] Returning polygons if any of a polygon input points lie in the polygons
Rémi:
Yes, that worked perfectly. Thanks!
My input poly will be stored in another database (maybe just another table). It would be nice to perform the query all on 1 line (get the poly and use it for the query), but I can query the first table first to get the input poly, then use that for the 2nd query without too much difficulty.
Thanks again for the responses!
Regards,
Joseph Spenner
If life gives you lemons, keep them-- because hey.. free lemons.
"~heart~ Sticker" fixer: http://microflush.org/stuff/stickers/heartFix.html
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Cc: Joseph Spenner <joseph85750 at yahoo.com>
Sent: Tuesday, November 18, 2014 4:20 AM
Something like this?
FROM polys
WHERE ST_Overlaps(ST_GeomFromText('POLYGON((-109 42,-108 42, -108 43; -109 43, -109 42))', 4269), geom)=TRUE;
Cheers,
Rémi-C
2014-11-18 9:00 GMT+01:00 Hugues François <hugues.francois at irstea.fr>:
Hello,
Maybe I don’t understand your problem very well but I think your query for points should work with a polygon using ST_GeomFromText (http://www.postgis.org/docs/ST_GeomFromText.html) for your input polygon or a subquery if it stored into your DB.
Hugues.
Envoyé : lundi 17 novembre 2014 22:35
Objet : [postgis-users] Returning polygons if any of a polygon input points lie in the polygons
Hello, I'm trying to perform a query which will return any polygons which have any points in common with an input polygon.
So, if I have Polygon A.
In my database, I have several other polygons stored.
I want to submit a query with Polygon A as the input, which will return all of the polygons in my database which have any points in common with Polygon A.
Can this be done?
I found this:
But from what I can tell, it only returns a T or F. I need to fetch the actual polygons if T.
I'm currently able to query with points as input:
select zone,gid,state,name,ST_Asgeojson( geom ) from polys where ST_Intersects(ST_PointFromText('POINT(-109 42)', 4269), geom);
But now I have a need to use polygons as input.
Any help would be great.
Thanks!
Regards,
Joseph Spenner
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141118/8bd0fc5e/attachment.html>
