[postgis-users] Returning polygons if any of a polygon input points lie in the polygons
Joseph Spenner
joseph85750 at yahoo.com
Tue Nov 18 07:49:53 PST 2014
Sorry for all the posts, but I think I found my answer. I can accomplish my goal with 2 querries:
1) using the ST_Overlaps+2) using the ST_Contains
So, I just need to combine those 2 in 1 single query somehow. I'm thinking..
select ugcstring from polys where ST_Overlaps(ST_GeomFromText('POLYGON((-82 31, -88 31, -88 35, -82 35, -82 31))', 4269), geom)=TRUE or ST_Contains(ST_GeomFromText('POLYGON((-82 31, -88 31, -88 35, -82 35, -82 31))', 4269), geom)=TRUE;
This seems to work!
If life gives you lemons, keep them-- because hey.. free lemons.
"~heart~ Sticker" fixer: http://microflush.org/stuff/stickers/heartFix.html
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Sent: Tuesday, November 18, 2014 8:44 AM
Subject: Re: [postgis-users] Returning polygons if any of a polygon input points lie in the polygons
Something I did notice though-- it seems that if the input polygon completely surrounds a polygon stored in my database, it is not included in the result. I read something about this here: http://postgis.net/docs/ST_Overlaps.html
"Returns TRUE if the Geometries "spatially overlap". By that we mean they intersect, but one does not completely contain another."
I do need the polygons which are completely contained as well. Can this be done?
Thanks again for the help. I'm getting there!
Regards,Joseph Spenner
To: Rémi Cura <remi.cura at gmail.com>; PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Sent: Tuesday, November 18, 2014 8:35 AM
Rémi: Yes, that worked perfectly. Thanks! My input poly will be stored in another database (maybe just another table). It would be nice to perform the query all on 1 line (get the poly and use it for the query), but I can query the first table first to get the input poly, then use that for the 2nd query without too much difficulty.
Thanks again for the responses!
Cc: Joseph Spenner <joseph85750 at yahoo.com>
Sent: Tuesday, November 18, 2014 4:20 AM
Something like this?
SELECT zone,gid,state,name,ST_Asgeojson( geom )
FROM polys
WHERE ST_Overlaps(ST_GeomFromText('POLYGON((-109 42,-108 42, -108 43; -109 43, -109 42))', 4269), geom)=TRUE;
Cheers,
Rémi-C
2014-11-18 9:00 GMT+01:00 Hugues François <hugues.francois at irstea.fr>:
Hello, Maybe I don’t understand your problem very well but I think your query for points should work with a polygon using ST_GeomFromText (http://www.postgis.org/docs/ST_GeomFromText.html) for your input polygon or a subquery if it stored into your DB. Hugues. De : postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] De la part de Joseph Spenner
Envoyé : lundi 17 novembre 2014 22:35
À : PostGIS Users Discussion
Objet : [postgis-users] Returning polygons if any of a polygon input points lie in the polygons Hello, I'm trying to perform a query which will return any polygons which have any points in common with an input polygon. So, if I have Polygon A.In my database, I have several other polygons stored. I want to submit a query with Polygon A as the input, which will return all of the polygons in my database which have any points in common with Polygon A. Can this be done?
I found this:http://postgis.net/docs/ST_Overlaps.html But from what I can tell, it only returns a T or F. I need to fetch the actual polygons if T. I'm currently able to query with points as input: select zone,gid,state,name,ST_Asgeojson( geom ) from polys where ST_Intersects(ST_PointFromText('POINT(-109 42)', 4269), geom);
But now I have a need to use polygons as input.
Any help would be great.
Thanks! Regards,Joseph Spenner
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141118/25c9d2aa/attachment.html>
