[postgis-users] Doubts dissolving geometries
Nicolas Ribot nicolas.ribot at gmail.com
Wed Nov 26 10:47:01 PST 2014
You can generate an id on-the-fly:
SELECT 1 as id, ST_union(st_buffer(emt_paradas.geom, 500)) FROM emt_paradas
Nicolas
On 26 November 2014 at 19:14, Luís Miguel Royo Pérez <
luis.miguel.royo at gmail.com> wrote:
>  Hi everyone,
> I'm trying to make a quite simple query in Postgis but I have problems
> with it. I just want to create a buffer dissolved of a set of points. Only
> that.
> This is the query I'm using:
> SELECT  emt_paradas.id , ST_union(st_buffer(emt_paradas.geom, 500)) FROM
> emt_paradas
> but when I try to execute this, tells me the field  emt_paradas.id must
> be in the clause group by but if I do that, the dissolve is not done.
> I'm in the DBManager of QGIS 2.6. I want to create this layer and load it
> in the canvas, for that DBManager asks me for an ID field, that's why I
> added emt_paradas.id in the select. If i remove it, Postgis creates the
> geometrybut I can't load it in the canvas.
> Any help or guidance will be apreciate.
> Thanks a lot!!
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141126/2ce7a433/attachment.html>
