[postgis-users] PostGIS supported by which ArcGIS
Birgit Laggner birgit.laggner at ti.bund.de
Thu Oct 2 00:30:58 PDT 2014
We use ArcGIS 10.2 for read/write interaction with our PostgreSQL
database. We only have ArcGIS Desktop without SDE. There is a driver
(database client file) from ArcGIS for PostgreSQL, you have to install.
We are more or less content with this concept. Surely, the performance
is not as if you would be working directly on the PostgreSQL database,
but still, it isn't necessary to always export and import into and from
shapefile. That's a huge plus in my opinion.
Here is a link to a documentation site of ArcGIS regarding the
requirements for the interoperability with PostgreSQL:
http://resources.arcgis.com/en/help/system-requirements/10.2/index.html#//015100000075000000
Regards,
Birgit.
Am 27.09.2014 20:28, schrieb Stefan Keller:
> Actually yes, I meant the "PostGIS option" of storing data in
> PostgreSQL/PostGIS from ArcGIS.
> --S.
> 2014-09-27 20:20 GMT+02:00 Randal Hale <rjhale at northrivergeographic.com>:
>> as far as I understand it (and I could be wrong on some of this)
>> Desktop will support reading if you load the postgresql library files (that
>> can be downloaded form your ESRI customer care portal).
>> Once those are loaded you can read through a definition query data from
>> postgis into arcgis. I just made a map using arcgis and reading data from
>> postgis.
>> It doesn't support write unless you have SDE for Postgresql - which isn't
>> postgis. That dives into the world of ArcGIS Server....
>> ArcGIS supposedly is moving to being able to read/write the geopackage
>> format which to me opens read/write to PostGIS. BUT if they open read write
>> for postgis that starts a slow death of SDE....so I don't believe it ever
>> will (for the foreseeable future).
>> Randy
>> On 09/27/2014 02:10 PM, Stefan Keller wrote:
>> I'm asked from time to time for an advice which ArcGIS product
>> supports PostGIS (read/write)?
>> Even after reading the Esri pages I'm not sure if it's only "ArcGIS
>> for Server Workgroup" (formerly ArcSDE).
>> Does it work also with ArcGIS for Desktop Basic (ArcView)?
>> Yours, S.
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>> Randal Hale
>> North River Geographic Systems, Inc
>> http://www.northrivergeographic.com
>> 423.653.3611 rjhale at northrivergeographic.com
>> twitter:rjhale http://about.me/rjhale
>> http://www.northrivergeographic.com/spatial-connect
