[postgis-users] PostGIS supported by which ArcGIS
David Haynes
haynesd2 at gmail.com
Thu Oct 2 07:20:17 PDT 2014
I have not been able to use Arc 10.3 for visualizing raster data stored in
postgresql
On Thu, Oct 2, 2014 at 2:30 AM, Birgit Laggner <birgit.laggner at ti.bund.de>
wrote:
> We use ArcGIS 10.2 for read/write interaction with our PostgreSQL
> database. We only have ArcGIS Desktop without SDE. There is a driver
> (database client file) from ArcGIS for PostgreSQL, you have to install. We
> are more or less content with this concept. Surely, the performance is not
> as if you would be working directly on the PostgreSQL database, but still,
> it isn't necessary to always export and import into and from shapefile.
> That's a huge plus in my opinion.
> Here is a link to a documentation site of ArcGIS regarding the
> requirements for the interoperability with PostgreSQL:
> http://resources.arcgis.com/en/help/system-requirements/10.2/index.html#//
> 015100000075000000
> Regards,
> Birgit.
> Am 27.09.2014 20:28, schrieb Stefan Keller:
> Actually yes, I meant the "PostGIS option" of storing data in
>> PostgreSQL/PostGIS from ArcGIS.
>> --S.
>> 2014-09-27 20:20 GMT+02:00 Randal Hale <rjhale at northrivergeographic.com>:
>>> as far as I understand it (and I could be wrong on some of this)
>>> Desktop will support reading if you load the postgresql library files
>>> (that
>>> can be downloaded form your ESRI customer care portal).
>>> Once those are loaded you can read through a definition query data from
>>> postgis into arcgis. I just made a map using arcgis and reading data from
>>> postgis.
>>> It doesn't support write unless you have SDE for Postgresql - which isn't
>>> postgis. That dives into the world of ArcGIS Server....
>>> ArcGIS supposedly is moving to being able to read/write the geopackage
>>> format which to me opens read/write to PostGIS. BUT if they open read
>>> write
>>> for postgis that starts a slow death of SDE....so I don't believe it ever
>>> will (for the foreseeable future).
>>> Randy
>>> On 09/27/2014 02:10 PM, Stefan Keller wrote:
>>> I'm asked from time to time for an advice which ArcGIS product
>>> supports PostGIS (read/write)?
>>> Even after reading the Esri pages I'm not sure if it's only "ArcGIS
>>> for Server Workgroup" (formerly ArcSDE).
>>> Does it work also with ArcGIS for Desktop Basic (ArcView)?
>>> Yours, S.
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>> Randal Hale
>>> North River Geographic Systems, Inc
>>> http://www.northrivergeographic.com
>>> 423.653.3611 rjhale at northrivergeographic.com
>>> twitter:rjhale http://about.me/rjhale
>>> http://www.northrivergeographic.com/spatial-connect
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141002/68e03bbb/attachment.html>
