[postgis-users] PostGIS supported by which ArcGIS
Birgit Laggner
birgit.laggner at ti.bund.de
Tue Oct 7 23:54:22 PDT 2014
Yes, that's true: ArcGIS is not able to read the PostGIS raster data type.
Am 02.10.2014 16:20, schrieb David Haynes:
> I have not been able to use Arc 10.3 for visualizing raster data
> stored in postgresql
> On Thu, Oct 2, 2014 at 2:30 AM, Birgit Laggner
> <birgit.laggner at ti.bund.de <mailto:birgit.laggner at ti.bund.de>> wrote:
> We use ArcGIS 10.2 for read/write interaction with our PostgreSQL
> database. We only have ArcGIS Desktop without SDE. There is a
> driver (database client file) from ArcGIS for PostgreSQL, you have
> to install. We are more or less content with this concept. Surely,
> the performance is not as if you would be working directly on the
> PostgreSQL database, but still, it isn't necessary to always
> export and import into and from shapefile. That's a huge plus in
> my opinion.
> Here is a link to a documentation site of ArcGIS regarding the
> requirements for the interoperability with PostgreSQL:
> http://resources.arcgis.com/en/help/system-requirements/10.2/index.html#//015100000075000000
> Regards,
> Birgit.
> Am 27.09.2014 20 <tel:27.09.2014%2020>:28, schrieb Stefan Keller:
> Actually yes, I meant the "PostGIS option" of storing data in
> PostgreSQL/PostGIS from ArcGIS.
> --S.
> 2014-09-27 20:20 GMT+02:00 Randal Hale
> <rjhale at northrivergeographic.com
> <mailto:rjhale at northrivergeographic.com>>:
> as far as I understand it (and I could be wrong on some of
> this)
> Desktop will support reading if you load the postgresql
> library files (that
> can be downloaded form your ESRI customer care portal).
> Once those are loaded you can read through a definition
> query data from
> postgis into arcgis. I just made a map using arcgis and
> reading data from
> postgis.
> It doesn't support write unless you have SDE for
> Postgresql - which isn't
> postgis. That dives into the world of ArcGIS Server....
> ArcGIS supposedly is moving to being able to read/write
> the geopackage
> format which to me opens read/write to PostGIS. BUT if
> they open read write
> for postgis that starts a slow death of SDE....so I don't
> believe it ever
> will (for the foreseeable future).
> Randy
> On 09/27/2014 02:10 PM, Stefan Keller wrote:
> I'm asked from time to time for an advice which ArcGIS product
> supports PostGIS (read/write)?
> Even after reading the Esri pages I'm not sure if it's
> only "ArcGIS
> for Server Workgroup" (formerly ArcSDE).
> Does it work also with ArcGIS for Desktop Basic (ArcView)?
> Yours, S.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> <mailto:postgis-users at lists.osgeo.org>
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> Randal Hale
> North River Geographic Systems, Inc
> http://www.northrivergeographic.com
> 423.653.3611 <tel:423.653.3611>
> twitter:rjhale http://about.me/rjhale
> http://www.northrivergeographic.com/spatial-connect
> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141008/cf79def3/attachment.html>
