[postgis-users] A little tired of non-noded intersections between polygons -- node them all
Sandro Santilli strk at keybit.net
Sat Oct 4 08:37:05 PDT 2014
On Fri, Oct 03, 2014 at 12:29:30PM -0600, John Abraham wrote:
> I’ve used all kinds of combinations of st_buffer(0),
> st_cleangeometry(), custom versions of st_cleangeometry(), and
> st_snaptogrid to try to fix things.
You hadn't mentioned http://postgis.net/docs/manual-2.0/ST_MakeValid.html
--strk;
 ()  ASCII ribbon campaign  --  Keep it simple !
 /\  http://strk.keybit.net/rants/ascii_mails.txt
