[postgis-users] postgis_full_version error
Paragon Corporation
lr at pcorp.us
Thu Oct 9 14:31:18 PDT 2014
Ben,
That function hasn't existed for a while in PostGIS. I would say circa 1.3.
I think it was a time when we were experimenting with using Java and JTS
natively in PostGIS.
I suspect you have a mix of PostGIS installs. Did you install a backup from
somewhere?
If so, you might be able to fix the issue by
Running postgis upgrade scripts.
Hope that helps,
Regina
http://www.postgis.us
http://postgis.net
G'day all,
I'm not sure if this is a postgis or an ubuntu issue, but having just
installed postgis on to ubuntu 14.04 from the pgdg repository, I am getting
this error :
# select postgis_full_version();
ERROR: function postgis_jts_version() does not exist
LINE 1: SELECT postgis_jts_version()
HINT: No function matches the given name and argument types. You might
need to add explicit type casts.
QUERY: SELECT postgis_jts_version()
CONTEXT: PL/pgSQL function postgis_full_version() line 15 at SQL
statement
I have previously installed onto many Ubuntu 12.04 without this problem. I
guess there are two parts:
1. do I have / need jts (it is showing geos 3.4.2-CAPI-1.8.2 r3921) ?
2. if I don't have it, should it fail completely, or just return NULL ?
cheers
Ben
