[postgis-users] postgis_full_version error
Ben Madin
ben at ausvet.com.au
Thu Oct 9 18:05:54 PDT 2014
G'day Regina,
You have nailed it, it was a database from an old (postgis 1.5) system - so
I actually expected to have many more errors. Luckily it was so old that I
had installed postgis into its own schema, so a simple DROP SCHEMA gis
CASCADE; has solved this problem.
I have 'noticed' this since upgrading a number of systems :
> NOTICE: Function postgis_topology_scripts_installed() not found. Is
topology support enabled and topology.sql installed?
We don't always need / use topology, so don't install it... is this notice
appearing a new behaviour, or have I messed up something else?
Thanks again,
cheers
Ben
On 10 October 2014 05:31, Paragon Corporation <lr at pcorp.us> wrote:
> Ben,
> That function hasn't existed for a while in PostGIS. I would say circa
> 1.3.
> I think it was a time when we were experimenting with using Java and JTS
> natively in PostGIS.
> I suspect you have a mix of PostGIS installs. Did you install a backup
> from
> somewhere?
> If so, you might be able to fix the issue by
> Running postgis upgrade scripts.
> Hope that helps,
> Regina
> http://www.postgis.us
> http://postgis.net
> G'day all,
> I'm not sure if this is a postgis or an ubuntu issue, but having just
> installed postgis on to ubuntu 14.04 from the pgdg repository, I am getting
> this error :
> # select postgis_full_version();
> ERROR: function postgis_jts_version() does not exist
> LINE 1: SELECT postgis_jts_version()
> HINT: No function matches the given name and argument types. You might
> need to add explicit type casts.
> QUERY: SELECT postgis_jts_version()
> CONTEXT: PL/pgSQL function postgis_full_version() line 15 at SQL
> statement
> I have previously installed onto many Ubuntu 12.04 without this problem. I
> guess there are two parts:
> 1. do I have / need jts (it is showing geos 3.4.2-CAPI-1.8.2 r3921) ?
> 2. if I don't have it, should it fail completely, or just return NULL ?
> cheers
> Ben
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Ben Madin
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141010/dd20d677/attachment.html>
