[postgis-users] Oriented BBox Efficient computing?
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Oct 23 06:46:07 PDT 2014
On 10/23/2014 9:33 AM, Rémi Cura wrote:
> Hey list,
> somebody has a good idea about how efficiently computing an approximate
> oriented bbox for a polygon ?
> The simplest approaches I can think of are
> - iteratively rotate the geom by few degrees, take the envelop. Keep
> ration where envelope is min
> - using Principal Components Analysis : extract points regularly
> spaced on border of object, compute PCA .
A couple of ideas:
* Compute convex hull and use that as simplification of the geometry.
* google: postgis minimum polygon width
if you can get the line representing the minimum width, then rotate the
to be horizontal or vertical
-Steve
