[postgis-users] Oriented BBox Efficient computing?
Rémi Cura remi.cura at gmail.com
Thu Oct 23 07:15:06 PDT 2014
Hey,
thanks for your help.
_I'm precisely looking for 2 axis (convex hull is excluded then)
_using the line where the polygon is the thinner as one of the bbox axis is
not going to work in several case
Cheers,
Rémi-C
2014-10-23 15:46 GMT+02:00 Stephen Woodbridge <woodbri at swoodbridge.com>:
> On 10/23/2014 9:33 AM, Rémi Cura wrote:
>> Hey list,
>> somebody has a good idea about how efficiently computing an approximate
>> oriented bbox for a polygon ?
>> The simplest approaches I can think of are
>>   - iteratively rotate the geom by few degrees, take the envelop. Keep
>> ration where envelope is min
>>   - using Principal Components Analysis  : extract points regularly
>> spaced on border of object,  compute PCA .
> A couple of ideas:
> * Compute convex hull and use that as simplification of the geometry.
> * google: postgis minimum polygon width
> if you can get the line representing the minimum width, then rotate the to
> be horizontal or vertical
> -Steve
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141023/dc3d38df/attachment.html>
