[postgis-users] Getting Started with PostGIS on Windows: Request for documentation review.
Paragon Corporation
lr at pcorp.us
Wed Oct 29 00:07:51 PDT 2014
Mark,
A couple of things I would change in the document
1) I wouldn't use template_postgis_20 and in fact if you are running 2.1,
that is the wrong template to use anyway.
You should instead create a database the normal way via pgAdmin with
template0 or default template1
Then do:
CREATE EXTENSION postgis;
(or in pgAdmin for newbies -- bit friendlier to go to the Extensions tree
section and select postgis)
Eventually I do plan to remove the whole template database thing from the
installer since things like search_paths are lost when installing from
template which is important for tiger and topology
2) For assigning default privileges in pgAdmin, I do see those. They show
both on the SQL pane and if you right click the database or the schema in
the Default Privileges tab (would show just for that schema)
I'm running pgAdmin 1.18.1 (so it could be you are running an older version
that didn't have that) or something about the mixed casing of your group
names is tripping it up.
3) Get rid of the WITH GRANT OPTION here because you don't want to give read
only users rights to grant read only to other users. You probably don't
want WITH GRANT OPTION with any of your groups except the administrator
groups
ALTER DEFAULT PRIVILEGES
GRANT SELECT ON TABLES
TO "GISUsersG" WITH GRANT OPTION;
So should be just
TO "GISUsersG";
Hope that helps,
Regina
http://www.postgis.us
http://postgis.net
---------------- ORIGINAL MESSAGE --
Hello,
I would like a peer review of some documentation that I put together that
covers how to get started with PostGIS on Windows. The instructions that I
have work, but I do not know if they are correct, or secure. The
documentation is located at:
http://geomoose.lyonco.org/PostGIS_New_Documentation.docx. I am putting this
documentation together so that I have more of a step by step instruction set
that will allow myself or other people the ability to use PostGIS as a
backbone to share our GIS data in an organization to ArcView, AutoCAD Map,
MapServer, and QGIS users.
Some of the concerns that I have are:
* Do I have the permissions set up correct?
* In the past I was able to preview data in ArcCatalog. I cannot
replicate the steps to allow previewing in Arc Catalog. Am I missing
something?
* I cannot view the default permissions for user groups in PGAdmin
III in Windows. Is there any reason why? Note: I was able to work around
the issue by running SQL.
Thank You for help.
Sincerely,
Mark Volz, GISP
