[postgis-users] pointcloud : change pcid ?
Rémi Cura
remi.cura at gmail.com
Wed Oct 29 04:54:37 PDT 2014
I'm sorry I think I was unclear.
I don't want to acces point,
I just want to change the pcid of a patch.
For the moment it seems to imply a complete destruction/reconstruction of a
new,
which is really really not efficient.
Basically in this case I would like a function PC_SetPCID(pcpatch)
I understand that such function is very hard to create in the genral case,
because you would have to put mappings between attributes.
Cheers.
Rémi-C
2014-10-28 19:08 GMT+01:00 Stephen V. Mather <svm at clevelandmetroparks.com>:
> Ah. Yes, I think if you are accessing a point within a patch, you have
> to unpack the patch. It's one of those tradeoffs...
> [image: http://sig.cmparks.net/cmp-ms-90x122.png] Stephen V. Mather
> GIS Manager
> (216) 635-3243 (Work)
> clevelandmetroparks.com <http://www.clemetparks.com>
> *From:* postgis-users-bounces at lists.osgeo.org <
> postgis-users-bounces at lists.osgeo.org> on behalf of Rémi Cura <
> remi.cura at gmail.com>
> *Sent:* Tuesday, October 28, 2014 1:33 PM
> *To:* PostGIS Users Discussion
> *Subject:* Re: [postgis-users] pointcloud : change pcid ?
> Now the only solution I found is to break a patch into point, then break
> point into attributes,
> then construct a new point with correct pcid and attributes, then
> construct a new patch !
> Cheers,
> Rémi-C
> 2014-10-28 17:31 GMT+01:00 Stephen V. Mather <svm at clevelandmetroparks.com>
>> How do you mean? What are you doing now?
>> GIS Manager
>> *Sent:* Tuesday, October 28, 2014 11:01 AM
>> *Subject:* [postgis-users] pointcloud : change pcid ?
>> Hey,
>> any pointcloud users has an idea about changing the pcid of a patch
>> without breaking it into pieces?
>> Cheers,
>> Rémi-C
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141029/fc24a94e/attachment.html>
