[postgis-users] Problem using ST_snap
Rémi Cura remi.cura at gmail.com
Wed Sep 24 04:46:38 PDT 2014
Hey,
snap is deceiptively named.
As far as I know It just snaps points to points (or points in geometry to
points in geometry).
For exemple, if you draw 2 square side by side, one being bigger than the
other, and separate theim with small distance, snap will do nothing.
Cheers,
Rémi-C
2014-09-24 13:41 GMT+02:00 Alexandre Neto <senhor.neto at gmail.com>:
> Hello all,
> I have to tables in postgis. table one has a set of adjacent polygons that
> covers all my area o interest, while table to have a few polygons across
> the same area.
> Some boundaries of table 2 should snap to the table 1 polygons, but they
> don't.
> I'm trying to use st_snap to correct this, but I'm not being able to do
> it. There are vertices that "refuse" to change while other (just a few do).
> I'm already using a very big tolerance.
>  Therefore I need your help to see if my query looks correct or not.
> WITH snap_grid as
> SELECT
>     St_Collect(f.geom) as geom
> FROM
>     table_1 as f
> SELECT
>     r.gid, st_snap(r.geom,q.geom,10) as geom
> FROM
>     table2 as r,
>     snap_grid as q
> WHERE r.gid = 53
> I already tried dumping all point form the table 1 polygons, but the
> result is "similar".
> Thanks in advance,
> Alexandre Neto
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140924/dbbc5457/attachment.html>
