[postgis-users] Beginning in PostGIS
Luciano
br.analistagis at gmail.com
Sat Apr 18 09:11:38 PDT 2015
Yes, I'm using QGIS. I agree, if I make a table in the database with the
same structure the shape file is simple. The copy / paste works perfectly.
But my question is how to update for example the blocks table, using the copy
/ paste, since the database structure is different.
For example, if I copy a polygon layer shape, and try to stick to the
database layer, the fields of the new polygon will be void.
Note that my database blocks table does not have the same structure of
the shape
file because it is normalized (or should be), so the fields of two data
sources do not match.
In this case, what is the best practice?
tia
2015-04-18 12:44 GMT-03:00 James Keener <jim at jimkeener.com>:
> tl;dr: Have you tried QGIS?
> What were you using to copy/paste before? I didn't think straight
> editing of the DBaseIII files directly was a sane thing to do, as
> they're linked up with the shape and shape-index files.
> PostGIS is just a PostgreSQL database, so any editor that can allow you
> to edit/duplicate PostgreSQL tables could work. As for mutating
> geometries, maybe QGIS? That would also allow you to edit geometries,
> attributes, as well as duplicate features.
> Hope that helps,
> Jim
> On 04/18/2015 11:39 AM, Luciano wrote:
> > Hi,
> > I wonder how can I update a postgresql postgis database before the
> > following scenario:
> > Always worked with shape files and update them used copy / paste between
> > files.
> > Now, think about creating a database in PostgreSQL and would like to
> > continue using copy / paste to update polygons, but in my database
> > structure is different from the shape file. For example:
> > Imagine that the shapefile have all the fields in one table, already in
> > the database, by reason of standardization, have these columns in tables
> > distinct. Below is an example of a register of towns.
> > File shape, columns:
> > town code;
> > town description;
> > Neighborhood code;
> > name of the neighborhood;
> > block code;
> > Street code;
> > street name;
> > In Postgres / Gis could look like this:
> > Cities table (data):
> > - Town id
> > - Description of town
> > Neighborhoods table (data):
> > - Id of the neighborhood
> > - Description of the neighborhood
> > - Id of town (foreign key)
> > Blocks table:
> > - Id of the court
> > - Block of code
> > - Town id (foreign key)
> > - Geometry, polygon
> > Streets table:
> > - Street id
> > - Street name
> > - Geometry, line
> > How could update (insert) a block in postgresql table using copy / paste
> > the shape file?
> > Would have to create a trigger/procedure (instead of) to automate the
> > process?
> > Fields of shape file should be equal to the fields of database table?
> > Some practical example as a reference?
> > tia
> > Luciano
> > postgis-users mailing list
> > postgis-users at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Luciano
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150418/2240ed40/attachment.html>
