[postgis-users] Can geocode() deal with NYC Hyphenated address numbers and other special types?
dracodoc dracodoc at gmail.com
Tue Dec 1 08:12:46 PST 2015
Thanks! I total understand the complexity of these special cases, so I
think I'll just ignore the other type of special cases.
As for the NYC address, I tried these variations:
DROP TABLE IF EXISTS addresses_to_geocode;
CREATE TABLE addresses_to_geocode(address text);
INSERT INTO addresses_to_geocode(address)
VALUES     ('40-12 28 AVE , New York City, NY 11103'),
        ('40 28 AVE , New York City, NY 11103');
select     g.address as input_address,
        pprint_addy(normalize_address(g.address)) as normal_input,
        pprint_addy((g.geo).addy) as normal_output,
        (g.geo).rating
from (select address, (geocode(address,1)) as geo
        from addresses_to_geocode
     ) as g;
Results:
So the block number 40 is not recognized anyway. I think the normalize
function is doing the right thing to just ignore the part "-12", but the
block number is not a street number so cannot be geocoded?
Thanks a lot for the help!
On Monday, November 30, 2015 at 9:51:55 PM UTC-5, Paragon Corporation wrote:
> Steve's comments are right.
> I have to double-check how I do the address range thing.  As I might be
> stripping off the - which would be the wrong thing to do and might be why
> your 40 is not being kept.
> I think the address_standardizer just keeps them together and then when it
> get's to my casting function, it might just strip off the minus.
> Anyway give the address_standardizer a try.  The work Steve and I will be
> doing is focusing on making that better so it can be used in future
> geocoders.
> Thanks,
> Regina
> -----Original Message-----
> From: postgis-users [mailto:postgis-us... at lists.osgeo.org <javascript:>]
> On Behalf Of Stephen Woodbridge
> Sent: Monday, November 30, 2015 4:21 PM
> To: postgi... at lists.osgeo.org <javascript:>
> Subject: Re: [postgis-users] Can geocode() deal with NYC Hyphenated
> I do not believe it is able to deal with  milepost, grid-style, or
> hyphenated house numbers other than the fact that it can pull off the first
> number and might use that to interpolate.
> First understand that it only do linear interpolation between two number
> in a range. These complex numbers do not lead themselves to simple linear
> interpolation. I did an analysis of these address number in the past in
> Tiger data. Specifically, I compared the address ranges, to look at which
> components of the number were constant between the start and end of the
> range and which parts varied over the range.
> It was not obvious in many cases which numbers to use for the
> interpolation and in some cases it was totally impossible to interpolate
> because the numbers collected did not make sense (block number at start and
> single number at end) either through a typographical error in the data or
> based on who collected the numbers at the end of the segments or how
> numbers were reassigned when a segment got divided into multiple segments.
> Also remember you are working with Tiger data which fuzzes the address
> ranges because of Title 13 concerns.
> I'll let others respond to the specifics of the postgis geocoder.
> -Steve
> On 11/30/2015 3:56 PM, draco doc wrote:
> > Hi,
> > I found there are many special format of addresses that valid in their
> > local area, but could be quite difficult for geocode() in Tiger Geocoder.
> > Here is a US street address standard document
> https://www.fgdc.gov/standards/projects/FGDC-standards-projects/street-address/index_html
> > Started from page 36 of the final draft, several special cases were
> listed:
> > 4. Milepost Complete Address Numbers (Example: "Milepost 240").
> > 5. Grid-style Complete Address Numbers (Example:
> > "N89W16758"). In certain communities in and around southern Wisconsin,
> > Complete Address Numbers include a map grid cell reference preceding
> > the Address Number.
> > 6. Hyphenated Complete Address Numbers (Example: "5- 5415"). In some
> > areas (notably certain parts of New York City, southern California,
> > and Hawaii), Complete Address Numbers often include hyphens.
> > I have 18 million address to geocode, and all these special cases can
> > be found in my data. From my test, geocode() seemed not be able to
> > recognize these cases which is totally understandable for me.
> > My questions is, is it possible to modify input a little bit to get a
> > better than nothing result?
> > For example, if the NYC hyphenated address cannot be recognized, can
> > we at least remove some part and get a rough location? I have address
> > like this "40-12 28 AVE , New York City, NY 11103", where 40 is block,
> > 12 is house number in block. I tried to just remove the 12 and keep
> > the 40 which is block number, but all I can get is still just the 28 ave.
> > Thanks!
> > postgis-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20151201/2f43ce4a/attachment-0001.html>
Name: Auto Generated Inline Image 1
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20151201/2f43ce4a/attachment-0001.png>
