[postgis-users] PostGIS data in the marine environment
Terry
terry.curran at shaw.ca
Tue Dec 1 12:02:53 PST 2015
We have been investigating how to get our marine data into and out of
our PostGIS
- GeoServer - GeoNetwork on a CentOS system, and we are looking for
some advice.
We often have the situation of marine data obtained from a sonde lowered
vertically through the water column.
The resulting data consists of a lat-long location, datetime, and
sensors typically measuring water temperature,
conductivity, dissolved oxygen and chlorophyll fluorescence as a
function of pressure.
We have typically created CSV files and entered them into PostGIS. We
create a spatial index based upon the
2D lat-long position. This approach does not seem to maximally use the
"relatedness" of the cast information.
We are considering creating for each horizontal location and datetime a
series of linestrings of (pressure, parameter) tuples,
and then reading these into PostGIS. The resulting table records could
then be up to a thousand times shorter, and searches potentially faster.
This may imply that we need to write an application to form these
linestrings, and another to create SQL commands.
Alternatively, we are looking for a nice way to create NetCDF data from
our profile data, and then input that into PostGIS.
Any suggestions on contemplated approaches, or advice or links to prior
technology for a similar situation?
-- terry
