[postgis-users] English please
Rémi Cura
remi.cura at gmail.com
Tue Feb 3 06:56:42 PST 2015
You are welcom
It wasn't a bug, so no ticket, so nothing to do ;-)
Cheers,
Rémi-C
~~~~~~~Français~~~~~~~~~
Pas de problème,
comme il ne s'agissait pas d'un bug, je n'ai pas créé de ticket, donc il
n'y a rien à faire.
Salutations,
Rémi-C
2015-02-03 14:53 GMT+01:00 Guillaume ARNAUD <guillaume.arnaud at cg82.fr>:
> Thank you for your help. The example is exactly what I need.
> I apologize for speaking French to other users. If I again need help or if
> one day I can bring my own, I will try to do it in English.
> Good job for this function Remi and thank you again.
> How can i close this topic and note that my problem is solved?
> Cheers,
> Guillaume
> Le 03/02/2015 13:10, Rémi Cura a écrit :
> /*french version at the end*/
> Ok I think I found the problem :
> your geometry are not simple, that is in postgis langage, there is no
> selfintersection.
> Your lines have tone of selfintersection , which is forbiden (because
> GEOS does topological computation)!
> So now of to fixe this : use this function
> <https://github.com/Remi-C/PPPP_utilities/blob/master/postgis/rc_makesimple.sql>
> to transform your non-simple (multi)line into multiline where each line
> inside is simple.
> You code becomes :
> SELECT objectid, nom, code
> , ST_OffsetCurve(dmp.geom, 25, 'quad_segs=4 join=round') as
> offseted_linestring
> FROM web.trs_itineraire , st_Dump(rc_MakeSimple(shape)) as dmp
> WHERE code = '06-20B'
> It execute successfully (now does it do what you expect, I don't know)
> (tested on the data you shared, no translation, no snapping)
> Cheers,
> Rémi-C
> ~~~~~~~~ French version ~~~~~~~~
> J'ai trouvé le problème je pense.
> En fait les géométries ne sont pas simple au sens de PostGIS, c'est à dire
> "qui ne s'autointersecte pas".
> Cela est interdit et cause les erreurs de GEOS (qui fait du calcul
> topologique).
> Maintenant la solution pour régler simplement le problème :
> utiliser cette fonction
> pour passer de (multi)lignes avec des autointersections à des multilignes
> dont chaque lignes composante ne s'autointersecte pas.
> Du coup,
> votre code devient :
> offseted_linestring
> La requete s'execute sans erreurs (après le résultat ne sera pas
> nécessairement ce que vous attendez, mais c'est une autre histoire).
> (testé sur les données que vous avez partagées, sans translation ni
> snapping).
> Salutations,
> Rémi-C
> 2015-02-03 9:12 GMT+01:00 Sandro Santilli <strk at keybit.net>:
>> On Sun, Feb 01, 2015 at 08:46:16PM +0100, Rémi Cura wrote:
>> > We are coming closer to a GEOS or PostGIS bug.
>> Please use the bug tracker for these, thanks.
>> --strk;
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> postgis-users mailing listpostgis-users at lists.osgeo.orghttp://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> Guillaume ARNAUD
> Cellule SIGD
> Direction de l'Informatique
> Conseil Général de Tarn-et-Garonne
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150203/fb97f2bd/attachment.html>
