[postgis-users] Getting TopologyExections when trying to node linestrings to create an overlay
John Abraham
jea at hbaspecto.com
Sun Feb 8 18:31:59 PST 2015
Well I could say that using PostGIS ST_Intersects with "messy data" always seems to give me TopologyExceptions. I've had luck with various combinations of ST_SnapToGrid and ST_Buffer(0), but with messy data there always seems to be some weird case that requires manually edits. Sorry to be the bearer of bad news. Frankly, I don't understand why the GEOS library has to throw that error.
I would encourage you to isolate particular problems and file bug reports. Improvements in GEOS to eliminate the underlying error(s) would certainly be welcome.
John Abraham
> On Feb 8, 2015, at 1:43 PM, BladeOfLight16 <bladeoflight16 at gmail.com> wrote:
> On Tue, Feb 3, 2015 at 11:28 AM, BladeOfLight16 <bladeoflight16 at gmail.com <mailto:bladeoflight16 at gmail.com>> wrote:
> I'm trying to create a polygon overlay. The basic process is relatively simple: 1) Get the boundaries 2) Union the boundaries to node the linestrings 3) Polygonize the noded outlines 4) Filter out holes using a contains or intersects test. The problem I'm running into is that I'm getting "GEOSUnaryUnion: TopologyException: found non-noded intersection between LINESTRING" errors from ST_Union.
> [a lot snipped]
> I haven't seen any response to this. I was just wondering if anyone else had a chance or intentions to look this over. Granted, it's pretty long and involved (sorry for that), but I thought all the details I included were important. I do know it went through the mailing list; someone on IRC helped me find it in the... I guess it's not the archives; I don't know what it's called. But the online browsing mechanism. Thanks to anyone who's taking a look.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150208/dafc66f8/attachment.html>
