[postgis-users] operator is not unique: text || geometry
Miller, Stephan
smille12 at harris.com
Tue Feb 17 08:16:41 PST 2015
Remi –
Thanks for your response.
I tried to use “execute format('CREATE TABLE %I AS SELECT objectid, f_code, shape FROM %I ; ', updatedtablename, tablename) ;” as you suggested. I got the following error
ERROR: prepared statement "format" does not exist
********** Error **********
SQL state: 26000
Do I need to use a PREPARE statement to define “format” to be able to execute this syntax?
Also, when I try to use
“ EXECUTE 'SELECT topology.CreateTopology(%s,32648, 0.001, TRUE) ; ',clean_topo;
I get :
ERROR: syntax error at or near "'SELECT topology.CreateTopology(%s,32648, 0.001, TRUE) ; '"
LINE 1: EXECUTE 'SELECT topology.CreateTopology(%s,32648, 0.001,...
SQL state: 42601
Character: 13
Finally, when I try to perform the UPDATE using _q (declared as text) as follows:
_q:=
'UPDATE fgcm.'||updatedtablename||' SET '||topo_shape||'::topogeometry
= topology.toTopoGeom(ST_Transform('||r.shape||'::geometry,32648), '||cleantopo||', 1, 1.0)
WHERE '||objectid||' = '||r.objectid||';';
RAISE EXCEPTION 'here is the query to manually test : %',_q ;
I get:
ERROR: syntax error at or near "_q"
LINE 1: _q:=
SQL state: 42601
Character: 13
I also tried formulating it like this:
_q:=
'UPDATE fgcm.%s SET %s::topogeometry
= topology.toTopoGeom(ST_Transform(%s,32648), %s, 1, 1.0)
WHERE %s = %s,' updatedtablename, topo_shape, r.shape, cleantopo, objectid, r.objectid;
I left the explicit typecast to topogeometry in place, but tried to replace all others with simple strings.
The query executed 21 seconds then failed with:
SQL state: 42601
Character: 13
I am executing this through pgAdmin.
Any other suggestions would be appreciated.
Steve
Sent: Tuesday, February 17, 2015 4:56 AM
To: PostGIS Users Discussion; Miller, Stephan
Subject: Re: [postgis-users] operator is not unique: text || geometry
Hey Stephan,
I'm afraid I must say the coding style is not good and dangerous.
And I know that the very nature of plpgsql langage (and doc) make it difficult to produce a nice function.
AS it is, it is very hard to read it, and any user of your function could potentially inject SQL via your function.
For instance,
execute 'CREATE TABLE ' || updatedtablename || ' AS SELECT objectid, f_code, shape FROM ' || tablename;
should become (safe, easier to read, easier to port)
execute format('CREATE TABLE %I AS SELECT objectid, f_code, shape FROM %I ; ', updatedtablename,tablename) ;
AS a rule of thumb, you should start asking yourself question when you abuse quoting, like ~'''~
For instance
execute 'SELECT topology.CreateTopology(''' || cleantopo || ''',32648, 0.000001, TRUE);';
could simply be replaced by
PERFORM topology.CreateTopology(clean_topo,32648, 0.000001, TRUE) ;
or, if you really really want to use an EXECUTE :
EXECUTE 'SELECT topology.CreateTopology(%s,32648, 0.000001, TRUE) ; ',clean_topo ) ;
You might also use the type 'regclass' instead of the type text when the text shall always represent a table.
This would automatically raise error if the table doesn't exist, and would be schema-qualification safe.
Now to the supposed-to-be-faulty part, you have a sql problem on top of plpgsql problem.
I would recommend to always fabricate your sql statement, then test it manually, then execute it.
for instance, you could declare
_q text;
then you fabricate your query :
_q :=
then you print _q and execute it manually to see if the sql syntax is correct :
(copy past the query given at execution time, then try to execute it in pgadmin or psql to check that syntax is correct).
The problem in this query is that it doesn't respect the SQL UPDATE syntax :
you should do something like :
UPDATE your_table_name SET (-list_of_columns_to_update-) = (expression_matching_list_of_columns) WHERE ...
So you can see that "SET '||topo_shape||'::topogeometry" is not correct.
It is the same for your WHERE part :
"WHERE '||objectid||' = '||r.objectid||';';"
Now it could be a feature of your code (like storing the name of columns to use in another table), I don't understand it sufficiently to say so.
Cheers,
Rémi-C
2015-02-17 10:04 GMT+01:00 Sandro Santilli <strk at keybit.net<mailto:strk at keybit.net>>:
On Mon, Feb 16, 2015 at 10:02:14PM +0000, Miller, Stephan wrote:
> I highlighted where I think the error is occurring in red below.
Please, *please*, don't use colors to highlight texts.
I know we're in 2015 and the internet is full of colorful moving puppets,
but if we stick to low tech it's easier for everyone to partecipate.
Personally, I don't see colors in emails.
--strk;
postgis-users mailing list
postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150217/40c18277/attachment.html>
