[postgis-users] operator is not unique: text || geometry
Rémi Cura remi.cura at gmail.com
Tue Feb 17 08:36:39 PST 2015
Here is the "cleaned" version, still no good tough.
I don't understand what you want to do, I don't have your table structure
nor your data, so you will need to work from that.
CREATE OR REPLACE FUNCTION hc_check_gaps_in_linear_topology(IN tablename
text, IN cleantopo text)
  RETURNS TABLE(objectid integer, f_code character varying, topo_shape
topogeometry) AS
$BODY$
declare
    updatedtablename text;
DECLARE
    r record;
    _q text;
BEGIN
    -- SELECT sde_set_current_version(10.2.1);
updatedtablename = 'updated' || tablename;
_q := format('CREATE TABLE %I  AS SELECT objectid, f_code, shape  FROM %I ;
' ,updatedtablename,tablename) ;
EXECUTE _q ;
PERFORM topology.DropTopology(cleantopo );
-- Create a new topology
-- Note need to generalize the SRID calculation to select the best fit UTM
zone based on longitude extents
PERFORM topology.CreateTopology(cleantopo ,32648, 0.000001, TRUE);
PERFORM  topology.AddTopoGeometryColumn( cleantopo , fgcm ,
 updatedtablename ,'topo_shape','LINESTRING');
PERFORM  topology.TopologySummary(cleantopo );
_q := format('SELECT objectid, f_code, shape, topo_shape FROM
fgcm.%I',updatedtablename);
 FOR r IN
EXECUTE _q
LOOP
BEGIN
RAISE NOTICE 'Loading % attempt with shape = % and topo_shape = %' ,
r.objectid, r.shape, r.topo_shape;
_q :=
format('UPDATE fgcm.%I SET %I::topogeometry
= topology.toTopoGeom(ST_Transform($1::geometry,32648), %I, 1, 1.0)
WHERE  objectid = $2' ,updatedtablename,topo_shape,cleantopo);
 EXECUTE _q USING r.shape, r.objectid ;
    RAISE NOTICE 'Object % after conversion from shape = % to topo_shape =
%', r.objectid, (ST_AsText(r.shape)), (ST_AsText(r.topo_shape));
EXCEPTION
    WHEN OTHERS THEN
RAISE WARNING 'Loading of record % failed: % %', r.objectid, SQLSTATE,
SQLERRM;
END;
END LOOP;
    RETURN;
END
$BODY$
  LANGUAGE plpgsql VOLATILE
  COST 100
  ROWS 2000;
Cheers,
Rémi-C
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150217/7004e201/attachment.html>
