[postgis-users] POSTGIS_ENABLE_OUTDB_RASTERS=1: PostGIS won't start (RHEL 6.5)
Bborie Park
dustymugs at gmail.com
Wed Feb 25 12:25:51 PST 2015
Can you post the shell script?
On Wed, Feb 25, 2015 at 11:50 AM, Phil Hurvitz <phurvitz at uw.edu> wrote:
> Thanks Bborie, I am starting with a shell script, and have added the env
> vars to that script, but am still unable to access the out-db rasters.
> -P.
> Philip M. Hurvitz, PhD | Research Assistant Professor | UW-CBE
> Urban Form Lab | 1107 NE 45th Street, Suite 535 | Box 354802
> University of Washington, Seattle, Washington 98195-4802, USA
> phurvitz at u.washington.edu | http://gis.washington.edu/phurvitz
> "What is essential is invisible to the eye." -de Saint-Exupéry
> On 2/25/2015 11:45, Bborie Park wrote:
>> The env variables need to be within the environment of the postgres
>> process. How are you starting postgres?
>> Shell script? Then you should be able to add the variables to that script.
>> Direct invocation of posrgres on the command line? You need to have the
>> variables before the command
>> VAR=1 postgres ...
>> -bborie
>> On Feb 25, 2015 11:40 AM, "Phil Hurvitz" <phurvitz at uw.edu
>> <mailto:phurvitz at uw.edu>> wrote:
>> Thanks Bborie, I built from the tarball rather than using an rpm;
>> does that still mean I should be adding the environment variables to
>> /etc/sysconfig/pgsql/__postgresql
>> So for overkill I added the env vars to that file as well as to the
>> init script, restarted PostgreSQL, and it seems I still cannot
>> access the out-db raster.
>> I added a slope raster using:
>> raster2pgsql -I -C -e -Y -F -d -R -s 2926 ./slope/slope_ps.tif
>> gis.slope | psql osm_test
>> I can get metadata (sorry for the ugly text wrapping):
>> select rid, (foo.md <http://foo.md>).* from (select rid,
>> st_Metadata(rast) as md from slope) as foo;
>> rid | upperleftx | upperlefty | width | height |
>> scalex | scaley | skewx | skewy | srid | numbands
>> -----+------------------+-----__-------------+-------+------
>> --__+------------------+----------__---------+-------+------
>> -+----__--+----------
>> 1 | 835161.301005914 | 758483.868026069 | 31935 | 34649 |
>> 32.8083333333333 | -32.8083333333333 | 0 | 0 | 2926 | 1
>> But cannot access values:
>> select st_summarystats(rast) from slope;
>> ERROR: rt_raster_load_offline_data: Access to offline bands disabled
>> CONTEXT: SQL function "st_summarystats" statement 1
>> select st_value(rast, 1, 1, 1) from slope;
>> -P.
>> ******************************__******************************__**
>> phurvitz at u.washington.edu <mailto:phurvitz at u.washington.edu> |
>> http://gis.washington.edu/__phurvitz
>> <http://gis.washington.edu/phurvitz>
>> Bborie Park dustymugs at gmail.com <mailto:dustymugs at gmail.com>
>> Wed Feb 25 10:46:59 PST 2015
>> Philip,
>> POSTGIS_ENABLE_OUTDB_RASTERS=1 is an environment variable not to
>> be in
>> postgresql.conf.
>> The same is true for POSTGIS_GDAL_ENABLED_DRIVERS=__ENABLE_ALL
>> https://wiki.postgresql.org/__wiki/PostgreSQL_on_RedHat___Linux
>> <https://wiki.postgresql.org/wiki/PostgreSQL_on_RedHat_Linux>
>> Based upon the above, it looks like you should add
>> to /etc/sysconfig/pgsql/__postgresql
>> The above assumes you're using the packages provided by
>> PostgreSQL.
>> http://www.postgresql.org/__download/linux/redhat/
>> <http://www.postgresql.org/download/linux/redhat/>
>> -bborie
>> On 2/25/2015 10:10, Phil Hurvitz wrote:
>> Hi all, I am having trouble starting PostGIS with out-db raster
>> support
>> In my /usr/local/pgsql/data/__postgresql.conf file I include the
>> line
>> after which PostGIS won't start (service postgresql start).
>> Software is
>> postgis_full_version
>> ------------------------------__----------------------------
>> --__-----------
>> POSTGIS="2.1.3 r12547" GEOS="3.4.2-CAPI-1.8.2 r3921"
>> PROJ="Rel. 4.7.1,
>> 23 September 2009" GDAL="GDAL 1.11.2, released 2015/02/10"
>> LIBXML="2.7.6" TOPOLOGY RASTER
>> Also PostGIS won't start when I specify
>> Any help would be appreciated!
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150225/04daef4e/attachment.html>
