[postgis-users] POSTGIS_ENABLE_OUTDB_RASTERS=1: PostGIS won't start (RHEL 6.5)
Phil Hurvitz phurvitz at uw.edu
Wed Feb 25 12:51:09 PST 2015
Thank you, Bborie. This seems to be a partial solution (at least now
PostGIS isn't complaining about the out-db raster). But now I get a
different problem, which is that attempting to access the out-db raster
makes the connection choke:
select st_summarystats(rast) from slope;
The connection to the server was lost. Attempting reset: Failed.
-P.
Philip M. Hurvitz, PhD | Research Assistant Professor | UW-CBE
Urban Form Lab  | 1107 NE 45th Street, Suite 535  | Box 354802
University of Washington, Seattle, Washington  98195-4802, USA
phurvitz at u.washington.edu | http://gis.washington.edu/phurvitz
"What is essential is invisible to the eye." -de Saint-Exupéry
On 2/25/2015 12:41, Bborie Park wrote:
> Ah. I use a script similar to this.
> In the following block...
> start)
>      su - $PGUSER -c "$DAEMON -D '$PGDATA' &" >>$PGLOG 2>&1
> You'll want to modify the su line to be like:
>      su - $PGUSER -c "POSTGIS_ENABLE_OUTDB_RASTERS=1
> POSTGIS_GDAL_ENABLED_DRIVERS=__ENABLE_ALL $DAEMON -D '$PGDATA' &"
>  >>$PGLOG 2>&1
> See if that works...
> -bborie
> On Wed, Feb 25, 2015 at 12:29 PM, Phil Hurvitz <phurvitz at uw.edu
> <mailto:phurvitz at uw.edu>> wrote:
>     Certainly!
>     ! /bin/sh
>     # chkconfig: 2345 98 02
>     # description: PostgreSQL RDBMS
>     # This is an example of a start/stop script for SysV-style init, such
>     # as is used on Linux systems.  You should edit some of the variables
>     # and maybe the 'echo' commands.
>     # Place this file at /etc/init.d/postgresql (or
>     # /etc/rc.d/init.d/postgresql) and make symlinks to
>     #   /etc/rc.d/rc0.d/K02postgresql
>     #   /etc/rc.d/rc1.d/K02postgresql
>     #   /etc/rc.d/rc2.d/K02postgresql
>     #   /etc/rc.d/rc3.d/S98postgresql
>     #   /etc/rc.d/rc4.d/S98postgresql
>     #   /etc/rc.d/rc5.d/S98postgresql
>     # Or, if you have chkconfig, simply:
>     # chkconfig --add postgresql
>     # Proper init scripts on Linux systems normally require setting lock
>     # and pid files under /var/run as well as reacting to network
>     # settings, so you should treat this with care.
>     # Original author:  Ryan Kirkpatrick <pgsql at rkirkpat.net
>     <mailto:pgsql at rkirkpat.net>>
>     # contrib/start-scripts/linux
>     ## EDIT FROM HERE
>     # Installation prefix
>     prefix=/usr/local/pgsql
>     # Data directory
>     PGDATA="/usr/local/pgsql/data"
>     # Who to run the postmaster as, usually "postgres".  (NOT "root")
>     PGUSER=postgres
>     # Where to keep a log file
>     PGLOG="$PGDATA/serverlog"
>     # It's often a good idea to protect the postmaster from being killed
>     by the
>     # OOM killer (which will tend to preferentially kill the postmaster
>     because
>     # of the way it accounts for shared memory).  Setting the
>     OOM_SCORE_ADJ value
>     # to -1000 will disable OOM kill altogether.  If you enable this,
>     you probably
>     # want to compile PostgreSQL with "-DLINUX_OOM_SCORE_ADJ=0", so that
>     # individual backends can still be killed by the OOM killer.
>     #OOM_SCORE_ADJ=-1000
>     # Older Linux kernels may not have /proc/self/oom_score_adj, but instead
>     # /proc/self/oom_adj, which works similarly except the disable value
>     is -17.
>     # For such a system, enable this and compile with "-DLINUX_OOM_ADJ=0".
>     #OOM_ADJ=-17
>     ## STOP EDITING HERE
>     # The path that is to be used for the script
>     PATH=/usr/local/sbin:/usr/__local/bin:/sbin:/bin:/usr/__sbin:/usr/bin
>     # What to use to start up the postmaster.  (If you want the script
>     to wait
>     # until the server has started, you could use "pg_ctl start -w" here.
>     # But without -w, pg_ctl adds no value.)
>     DAEMON="$prefix/bin/__postmaster"
>     # What to use to shut down the postmaster
>     PGCTL="$prefix/bin/pg_ctl"
>     set -e
>     # Only start if we can find the postmaster.
>     test -x $DAEMON ||
>              echo "$DAEMON not found"
>              if [ "$1" = "stop" ]
>              then exit 0
>              else exit 5
>              fi
>     # Parse command line parameters.
>     case $1 in
>        start)
>              echo -n "Starting PostgreSQL: "
>              test x"$OOM_SCORE_ADJ" != x && echo "$OOM_SCORE_ADJ" >
>              test x"$OOM_ADJ" != x && echo "$OOM_ADJ" > /proc/self/oom_adj
>              echo "ok"
>        stop)
>              echo -n "Stopping PostgreSQL: "
>              su - $PGUSER -c "$PGCTL stop -D '$PGDATA' -s -m fast"
>              echo "ok"
>        restart)
>              echo -n "Restarting PostgreSQL: "
>              su - $PGUSER -c "$PGCTL stop -D '$PGDATA' -s -m fast -w"
>              echo "ok"
>        reload)
>              echo -n "Reload PostgreSQL: "
>              su - $PGUSER -c "$PGCTL reload -D '$PGDATA' -s"
>              echo "ok"
>        status)
>              su - $PGUSER -c "$PGCTL status -D '$PGDATA'"
>              # Print help
>              echo "Usage: $0 {start|stop|restart|reload|__status}" 1>&2
>              exit 1
>     esac
>     exit 0
>     -P.
>     ******************************__******************************__**
>     phurvitz at u.washington.edu <mailto:phurvitz at u.washington.edu> |
>     http://gis.washington.edu/__phurvitz
>     <http://gis.washington.edu/phurvitz>
>     On 2/25/2015 12:25, Bborie Park wrote:
>         Can you post the shell script?
>         On Wed, Feb 25, 2015 at 11:50 AM, Phil Hurvitz <phurvitz at uw.edu
>         <mailto:phurvitz at uw.edu <mailto:phurvitz at uw.edu>>> wrote:
>              Thanks Bborie, I am starting with a shell script, and have
>         added the
>              env vars to that script, but am still unable to access the
>         out-db
>              rasters.
>              -P.
>         ******************************____****************************__**__**
>         <mailto:phurvitz at u.washington.__edu
>         <mailto:phurvitz at u.washington.edu>> |
>         http://gis.washington.edu/____phurvitz
>         <http://gis.washington.edu/__phurvitz>
>         <http://gis.washington.edu/phurvitz>>
>              On 2/25/2015 11:45, Bborie Park wrote:
>                  The env variables need to be within the environment of
>         the postgres
>                  process. How are you starting postgres?
>                  Shell script? Then you should be able to add the
>         variables to
>                  that script.
>                  Direct invocation of posrgres on the command line? You
>         need to
>                  have the
>                  variables before the command
>                  VAR=1 postgres ...
>                  -bborie
>                  On Feb 25, 2015 11:40 AM, "Phil Hurvitz"
>         <phurvitz at uw.edu <mailto:phurvitz at uw.edu>
>         <mailto:phurvitz at uw.edu <mailto:phurvitz at uw.edu>>>> wrote:
>                       Thanks Bborie, I built from the tarball rather
>         than using
>                  an rpm;
>                       does that still mean I should be adding the
>         environment
>                  variables to
>                       /etc/sysconfig/pgsql/______postgresql
>                       So for overkill I added the env vars to that file
>         as well
>                  as to the
>                       init script, restarted PostgreSQL, and it seems I
>         still cannot
>                       access the out-db raster.
>                       I added a slope raster using:
>                       raster2pgsql -I -C -e -Y -F -d -R -s 2926
>         ./slope/slope_ps.tif
>                       gis.slope | psql osm_test
>                       I can get metadata (sorry for the ugly text wrapping):
>                       select rid, (foo.md <http://foo.md>
>         <http://foo.md> <http://foo.md>).* from
>                  (select rid,
>                       st_Metadata(rast)  as md from slope) as foo;
>                         rid |    upperleftx    |    upperlefty    |
>         width | height |
>                       scalex      |      scaley       | skewx | skewy |
>         srid |
>                  numbands
>         -----+------------------+-----______-------------+-------+----__--__--__+------------------+--__----__----__---------+-------+__------__-+----__--+----------
>                           1 | 835161.301005914 | 758483.868026069 |
>         31935 |  34649 |
>                       32.8083333333333 | -32.8083333333333 |     0 |
>           0 | 2926
>                  |        1
>                       But cannot access values:
>                       ERROR:  rt_raster_load_offline_data: Access to offline
>                  bands disabled
>                       CONTEXT:  SQL function "st_summarystats" statement 1
>                       select st_value(rast, 1, 1, 1) from slope;
>                  bands disabled
>                       -P.
>         ******************************______**************************__**__**__**
>         Professor | UW-CBE
>         | Box 354802
>         98195-4802, USA
>         <mailto:phurvitz at u.washington.>____edu
>         <mailto:phurvitz at u.washington.edu>>> |
>         http://gis.washington.edu/______phurvitz
>         <http://gis.washington.edu/____phurvitz>
>         <http://gis.washington.edu/__phurvitz>>
>         <http://gis.washington.edu/phurvitz>>>
>         Saint-Exupéry
>                           Bborie Park dustymugs at gmail.com
>         <mailto:dustymugs at gmail.com>
>         <mailto:dustymugs at gmail.com>> <mailto:dustymugs at gmail.com
>                  <mailto:dustymugs at gmail.com <mailto:dustymugs at gmail.com>>>
>                           Wed Feb 25 10:46:59 PST 2015
>                           Philip,
>                           POSTGIS_ENABLE_OUTDB_RASTERS=1 is an environment
>                  variable not to
>                           be in
>                           postgresql.conf.
>                           The same is true for
>                  POSTGIS_GDAL_ENABLED_DRIVERS=______ENABLE_ALL
>         https://wiki.postgresql.org/______wiki/PostgreSQL_on_RedHat_______Linux
>         <https://wiki.postgresql.org/____wiki/PostgreSQL_on_RedHat_____Linux>
>         <https://wiki.postgresql.org/__wiki/PostgreSQL_on_RedHat___Linux>>
>         <https://wiki.postgresql.org/wiki/PostgreSQL_on_RedHat_Linux>>>
>                           Based upon the above, it looks like you should add
>                           to  /etc/sysconfig/pgsql/______postgresql
>                           The above assumes you're using the packages
>         provided by
>                  PostgreSQL.
>         http://www.postgresql.org/______download/linux/redhat/
>         <http://www.postgresql.org/____download/linux/redhat/>
>         <http://www.postgresql.org/__download/linux/redhat/>>
>         <http://www.postgresql.org/download/linux/redhat/>>>
>                           -bborie
>                       On 2/25/2015 10:10, Phil Hurvitz wrote:
>                           Hi all, I am having trouble starting PostGIS with
>                  out-db raster
>                           support
>                           In my
>         /usr/local/pgsql/data/______postgresql.conf file I
>                  include the
>                           line
>                           after which PostGIS won't start (service
>         postgresql start).
>                           Software is
>                           postgis_full_version
>         ------------------------------______--------------------------__--__--__-----------
>                              POSTGIS="2.1.3 r12547"
>         GEOS="3.4.2-CAPI-1.8.2 r3921"
>                           PROJ="Rel. 4.7.1,
>                           23 September 2009" GDAL="GDAL 1.11.2, released
>         2015/02/10"
>                           LIBXML="2.7.6" TOPOLOGY RASTER
>                           Also PostGIS won't start when I specify
>                           Any help would be appreciated!
