[postgis-users] TopologyException: geom is invalid
Roxanne Reid-Bennett rox at tara-lu.com
Thu Feb 26 12:16:15 PST 2015
On 2/26/2015 1:40 PM, Joseph Spenner wrote:
> I ran the following against all 4 of my GeoJSON files:
> SELECT ST_IsSimple(ST_GeomFromGeoJSON('@poly'))
> SELECT ST_IsValid(ST_GeomFromGeoJSON('@poly'))
> SELECT ST_IsValidDetail(ST_GeomFromGeoJSON('@poly'))
> SELECT ST_IsValidReason(ST_GeomFromGeoJSON('@poly'))
> where @poly contained each one of the following:
> http://microflush.org/stuff/json/MN.json
> http://microflush.org/stuff/json/mnz091.json
> http://microflush.org/stuff/json/CA.json
> http://microflush.org/stuff/json/nwsZone.json
> The select returned no error.  I tried to vary the input slightly to
> make sure I was using the proper syntax, and was able to get errors--
> such as:
> DBD::Pg::st execute failed: ERROR: geometry contains non-closed rings
> So, it would seem my geoms are ok.
> I've not yet tried the "ST_MakeValid". But wouldn't the above indicate
> they're already valid?
Yes ST_IsValid coming back true means that the geometry is "valid".
(Topology Exceptions are most often thrown during operations on invalid
geometries - so this test is the first that should be done when one
occurs...  in almost all cases)
In my (limited) experience - just because 2 geometries are valid,
doesn't mean that operations on them won't generate issues.
Is it the cast to Geography, ST_Intersection or the ST_Area on the
ST_Intersection that is throwing the error?
My guess is going to be the ST_Area on the results of the ST_Intersection.
So, is the result of the ST_Intersection of the two geographies valid?
Have you perhaps looked at all the involved geometries (since you are
down to 4) at the point identified by the original Topo  error in order
to understand exactly what in the makeup of those geometries makes the
error remotely possible within the operation you are performing on them?
ST_MakeValid and ST_Buffer adjust the geometry in (frequently
insignificant) ways that help operations avoid Topos.  But what
adjustment is likely to avoid the error when using the related valid
geometries is dependent upon the real cause for the error - and that is
specific to the geometries at the point identified in the error. Whether
those manipulations can validly be applied is dependent upon your
business use tolerance for those adjustments.  (buffering a polygon by
0.00001 will skew calculated area of a polygon but may not result in
false positives for an Intersects).
Roxanne
> Thanks!
> *From:* Joseph Spenner <joseph85750 at yahoo.com>
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Sent:* Thursday, February 26, 2015 8:05 AM
> *Subject:* Re: [postgis-users] TopologyException: geom is invalid
> Hello, and thanks for the replies!
> I'll try those suggestions.
> Just curiuos though-- which geometry seems to be invalid?  Is it the
> state poly, or the smaller county/zone poly?  If there was an invalid
> geometry, wouldn't it always show up for that state or county?  Here's
> what I observed for the CA issue:
> 1) I had 3 smaller county poly/geometries in CA. When performing my
> query, instead of returning the 3 polys, I received the error which I
> posted in my original thread.  I identified it was 1 of those 3.  I
> deleted that 1 offending geometry from my table.  After doing so, my
> query against CA turned up the remaining 2, with no errors.  So, that
> leads me to believe CA is ok.  Or is this not a valid assumption?
> Perhaps the location where that offending intersection would have
> occurred in the CA poly has an issue, and it doesn't get tickled
> unless the smaller county zone intersects it?
> 2) I was able to plot the offending county described above in the
> GeoJSONLint validation page: http://geojsonlint.com/
> There didn't appear to be any issues.
> Thanks!
> Regards,
> Joseph Spenner
> *From:* Rémi Cura <remi.cura at gmail.com>
> *Cc:* Joseph Spenner <joseph85750 at yahoo.com>
> *Sent:* Thursday, February 26, 2015 1:28 AM
> And also ST_IsSimple (that precisely check for self intersection).
> Cheers,
> Rémi-C
> 2015-02-26 8:32 GMT+01:00 BladeOfLight16 <bladeoflight16 at gmail.com
> <mailto:bladeoflight16 at gmail.com>>:
>     On Wed, Feb 25, 2015 at 12:14 PM, Joseph Spenner
>     <joseph85750 at yahoo.com <mailto:joseph85750 at yahoo.com>> wrote:
>         DBD::Pg::st execute failed: ERROR:  Error performing
>         intersection: TopologyException: Input geom 1 is invalid:
>         Self-intersection at or near point -381688.06935935974
>         -1206669.4272876547 at -381688.06935935974 -1206669.4272876547
>         at ./test.pl <http://test.pl/> line 151.
>     Did you try ST_IsValid to verify the geometry is valid according
>     to the OGC standard? (See
>     http://postgis.net/docs/using_postgis_dbmanagement.html#OGC_Validity.
>     ST_IsValidDetail and ST_IsValidReason are also helpful in this
>     regard.) What happens if you run it through ST_MakeValid? Be aware
>     that ST_MakeValid can sometimes result in GeometryCollections if
>     the input shape is malformed (usually "rings" without enough
>     points are that have different start and end points).
>     _______________________________________________
>     postgis-users mailing list
>     postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
>     http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
[At other schools] I think the most common fault in general is to teach students how to pass exams instead of teaching them the science.
Donald Knuth
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150226/a33c3867/attachment.html>
