[postgis-users] raster2pgsql is not creating a raster table in postgis
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Sun Jan 4 23:47:35 PST 2015
Try
SELECT (ST_Metadata(rast)).* FROM chp1.tmax1 LIMIT 1;
instead. It's more verbose. Your raster is there. Don't worry.
Pierre
________________________________________
From: postgis-users-bounces at lists.osgeo.org [postgis-users-bounces at lists.osgeo.org] On Behalf Of garret [garretlewis at gmail.com]
Sent: Sunday, January 04, 2015 11:04 PM
To: postgis-users at lists.osgeo.org
Subject: Re: [postgis-users] raster2pgsql is not creating a raster table in postgis
Hi Borie,
Thank you for you quick response, especially on a New Years Eve.
I took a look at the meta data,
Here is what I get:
SELECT ST_Metadata(rast) FROM chp1.tmax1 LIMIT 1;
"(-180,90,100,100,0.166666666666667,-0.166666666666667,0,0,4326,1)"
SELECT ST_BandMetadata(rast, 1) FROM chp1.tmax1 LIMIT 1;
"(16BSI,-9999,f,)"
Since this is my first time using rasters in postgis, I dont know if this is
typical output or not.
fyi, here is the gdalinfo output from the original file:
Files: tmax1.bil
tmax1.hdr
Size is 2160, 900
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9108"]],
AUTHORITY["EPSG","4326"]]
Origin = (-180.000000000000057,90.000000000000000)
Pixel Size = (0.166666666666667,-0.166666666666667)
Corner Coordinates:
Upper Left (-180.0000000, 90.0000000) (180d 0' 0.00"W, 90d 0' 0.00"N)
Lower Left (-180.0000000, -60.0000000) (180d 0' 0.00"W, 60d 0' 0.00"S)
Upper Right ( 180.0000000, 90.0000000) (180d 0' 0.00"E, 90d 0' 0.00"N)
Lower Right ( 180.0000000, -60.0000000) (180d 0' 0.00"E, 60d 0' 0.00"S)
Center ( 0.0000000, 15.0000000) ( 0d 0' 0.00"E, 15d 0' 0.00"N)
Band 1 Block=2160x1 Type=Int16, ColorInterp=Undefined
Min=-478.000 Max=418.000
NoData Value=-9999
the statement; SELECT * FROM raster_columns;
comes out a little odd, but again Im not sure what to expect. The output is
long but I can post a summary of it if you think it would be helpful.
So Im not sure where to go from here. Any recommendations?
Thank you,
Garret
View this message in context: http://postgis.17.x6.nabble.com/raster2pgsql-is-not-creating-a-raster-table-in-postgis-tp5007520p5007525.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
