[postgis-users] raster2pgsql is not creating a raster table in postgis
garret garretlewis at gmail.com
Mon Jan 5 13:15:21 PST 2015
Thanks for the help Pierre and Borie
after doing what you had suggested, as well as testing additional raster
files, it seemed to me that I may be barking up the wrong tree. So I looked
into any current QGIS issues with PostGIS rasters and found this:
http://hub.qgis.org/issues/10871 <http://hub.qgis.org/issues/10871>
So I opened DB Manager plugin (which I dont use typically) and viola! the
raster appeared.  So it seems that in QGIS version 2.6.1, you can not add
postgis rasters via the "Browser", nor the "Add PostGIS Layers" button -
they both end up only adding a table to the Layer.
Thanks again for you patience and help,
Garret
View this message in context: http://postgis.17.x6.nabble.com/raster2pgsql-is-not-creating-a-raster-table-in-postgis-tp5007520p5007527.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
