[postgis-users] problems with _st_distance() function on queries returning more than one row
Hartranft, Robert M. (GSFC-423.0)[RAYTHEON COMPANY]
robert.m.hartranft at nasa.gov
Thu Jan 8 14:09:49 PST 2015
Hi All,
I am hoping someone here has experience with the
issue I am having…
I am using:
-rw-r--r-- 1 postgres postgres 10241357 Oct 8 22:04 gdal-1.10.1.tar.gz
-rw-r--r-- 1 postgres postgres 1813726 Oct 8 22:04 geos-3.4.2.tar.bz2
-rw-r--r-- 1 postgres postgres 340953 Oct 8 22:04 json-c-0.9.tar.gz
-rw-r--r-- 1 postgres postgres 5161069 Oct 8 22:04 libxml2-2.9.0.tar.gz
-rw-r--r-- 1 postgres postgres 16930885 Oct 8 22:04 perl-5.16.3.tar.gz
-rw-r--r-- 1 postgres postgres 195442 Oct 8 22:04 pgtap-0.94.0.tar.gz
-rw-r--r-- 1 postgres postgres 6518378 Oct 8 22:04 postgis-2.1.0.tar.gz
-rw-r--r-- 1 postgres postgres 21865589 Oct 8 22:04 postgresql-9.3.4.tar.gz
-rw-r--r-- 1 postgres postgres 785279 Oct 8 22:04 proj-4.8.0.tar.gz
I have a table that contains a geography column.
The column contains “multipolygon” values.
When I do a query that uses the ST_Intersects() function it
seems to return the wrong results if the underlying plan uses
the _st_distance() function and it returns the correct results if
the plan uses the st_intersects() function.
I am having the issue with a multipolygon column but it might
happen of other types as well.
Here is an small example of the issue:
=# create table multipolygon
mpid bigint not null,
multip Geography(multipolygon, 4326) not null
CREATE TABLE
=# alter table multipolygon add constraint PK_POLYGON primary key (mpid);
ALTER TABLE
Now I will add two small “rectangles” into the table. I don’t really need to
use multiple polygons to reproduce the issue so I will use a single polygon with
points to approximate lines of constant latitude (just trying to avoid the great
circle arc).
=# insert into multipolygon
values (1, ST_GeographyFromText('SRID=4326;multipolygon(((20 10, 21 10, 22 10, 23 10, 24 10, 25 10, 26 10, 27 10, 28 10, 29 10, 30 10, 30 20, 29 20, 28 20, 27 20, 26 20, 25 20, 24 20, 23 20, 22 20, 21 20, 20 20, 20 10)))'));
INSERT 0 1
values (2, ST_GeographyFromText('SRID=4326;multipolygon(((25 15, 26 15, 27 15, 28 15, 29 15, 30 15, 31 15, 32 15, 33 15, 34 15, 35 15, 35 25, 34 25, 33 25, 32 25, 31 25, 30 25, 29 25, 28 25, 27 25, 26 25, 25 25, 25 15)))'));
INSERT 0 1
Now I run a query that should return both rows.
=# select m1.mpid from multipolygon m1 where st_intersects(m1.multip ,'POLYGON((27 17, 28 17, 28 19, 27 19, 27 17))'::geography);
mpid
1
(1 row)
=# select m1.mpid from multipolygon m1 where st_intersects((select multip from multipolygon m2 where m2.mpid = m1.mpid ),'POLYGON((27 17, 28 17, 28 19, 27 19, 27 17))'::geography );
mpid
1
2
(2 rows)
You can see the two queries seem to be logically the same but they return different results
Next I will look at the plans for the two queries
=# explain select m1.mpid from multipolygon m1 where st_intersects(m1.multip ,'POLYGON((27 17, 28 17, 28 19, 27 19, 27 17))'::geography);
QUERY PLAN
Seq Scan on multipolygon m1 (cost=0.00..317.40 rows=77 width=8)
Filter: ((multip && '0103000020E610000001000000050000000000000000003B4000000000000031400000000000003C4000000000000031400000000000003C4000000000000033400000000000003B4000000000000033400000000000003B400000000000003140'::geography) AND (_st_distance(multip, '0103000020E610000001000000050000000000000000003B4000000000000031400000000000003C4000000000000031400000000000003C4000000000000033400000000000003B4000000000000033400000000000003B400000000000003140'::geography, 0::double precision, false) < 1e-05::double precision))
(2 rows)
=# explain select m1.mpid from multipolygon m1 where st_intersects((select multip from multipolygon m2 where m2.mpid = m1.mpid ),'POLYGON((27 17, 28 17, 28 19, 27 19, 27 17))'::geography );
QUERY PLAN
Seq Scan on multipolygon m1 (cost=0.00..9788.80 rows=387 width=8)
Filter: st_intersects((SubPlan 1), '0103000020E610000001000000050000000000000000003B4000000000000031400000000000003C4000000000000031400000000000003C4000000000000033400000000000003B4000000000000033400000000000003B400000000000003140'::geography)
SubPlan 1
-> Index Scan using pk_polygon on multipolygon m2 (cost=0.15..8.17 rows=1 width=32)
Index Cond: (mpid = m1.mpid)
(5 rows)
You can see that the query using _st_distance is the one that returns a bad result.
However I can also show _st_distance() works if it is limited to finding just one
result. Here is the same query that didn’t work, however this time I add a constraint
to limit the result set to one row.
=# select m1.mpid from multipolygon m1 where st_intersects(m1.multip ,'POLYGON((27 17, 28 17, 28 19, 27 19, 27 17))'::geography) and m1.mpid = 1;
mpid
1
(1 row)
=# select m1.mpid from multipolygon m1 where st_intersects(m1.multip ,'POLYGON((27 17, 28 17, 28 19, 27 19, 27 17))'::geography) and m1.mpid = 2;
mpid
2
(1 row)
=# explain select m1.mpid from multipolygon m1 where st_intersects(m1.multip ,'POLYGON((27 17, 28 17, 28 19, 27 19, 27 17))'::geography) and m1.mpid = 2;
QUERY PLAN
Index Scan using pk_polygon on multipolygon m1 (cost=0.15..8.43 rows=1 width=8)
Index Cond: (mpid = 2)
(3 rows)
This might be the wrong conclusion but it appears that
_st_distance() doesn’t work if the result set contains more
than one row.
Thanks in advance,
Bob
Robert Hartranft
Mission Operations and Services
Intelligence & Information System
Raytheon Company
301-851-8197
robert_m_hartranft at raytheon.com<mailto:robert_m_hartranft at raytheon.com>
5700 Rivertech Court
Riverdale, MD 20737
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150108/2865601b/attachment.html>
