[postgis-users] problems with _st_distance() function on queries returning more than one row
Paul Ramsey
pramsey at cleverelephant.ca
Thu Jan 8 15:44:33 PST 2015
Move up to the latest patch revision of postgis, the 2.1.0 release
definitely had a few subtle issues with geography distance of the sort
you are describing.
P.
On Thu, Jan 8, 2015 at 2:09 PM, Hartranft, Robert M.
(GSFC-423.0)[RAYTHEON COMPANY] <robert.m.hartranft at nasa.gov> wrote:
> Hi All,
> I am hoping someone here has experience with the
> issue I am having…
> I am using:
> -rw-r--r-- 1 postgres postgres 10241357 Oct 8 22:04 gdal-1.10.1.tar.gz
> -rw-r--r-- 1 postgres postgres 1813726 Oct 8 22:04 geos-3.4.2.tar.bz2
> -rw-r--r-- 1 postgres postgres 340953 Oct 8 22:04 json-c-0.9.tar.gz
> -rw-r--r-- 1 postgres postgres 5161069 Oct 8 22:04 libxml2-2.9.0.tar.gz
> -rw-r--r-- 1 postgres postgres 16930885 Oct 8 22:04 perl-5.16.3.tar.gz
> -rw-r--r-- 1 postgres postgres 195442 Oct 8 22:04 pgtap-0.94.0.tar.gz
> -rw-r--r-- 1 postgres postgres 6518378 Oct 8 22:04 postgis-2.1.0.tar.gz
> -rw-r--r-- 1 postgres postgres 21865589 Oct 8 22:04
> postgresql-9.3.4.tar.gz
> -rw-r--r-- 1 postgres postgres 785279 Oct 8 22:04 proj-4.8.0.tar.gz
> I have a table that contains a geography column.
> The column contains “multipolygon” values.
> When I do a query that uses the ST_Intersects() function it
> seems to return the wrong results if the underlying plan uses
> the _st_distance() function and it returns the correct results if
> the plan uses the st_intersects() function.
> I am having the issue with a multipolygon column but it might
> happen of other types as well.
> Here is an small example of the issue:
> =# create table multipolygon
> mpid bigint not null,
> multip Geography(multipolygon, 4326) not null
> CREATE TABLE
> =# alter table multipolygon add constraint PK_POLYGON primary key (mpid);
> ALTER TABLE
> Now I will add two small “rectangles” into the table. I don’t really need
> to
> use multiple polygons to reproduce the issue so I will use a single polygon
> with
> points to approximate lines of constant latitude (just trying to avoid the
> great
> circle arc).
> =# insert into multipolygon
> values (1, ST_GeographyFromText('SRID=4326;multipolygon(((20 10, 21 10, 22
> 10, 23 10, 24 10, 25 10, 26 10, 27 10, 28 10, 29 10, 30 10, 30 20, 29 20, 28
> 20, 27 20, 26 20, 25 20, 24 20, 23 20, 22 20, 21 20, 20 20, 20 10)))'));
> INSERT 0 1
> values (2, ST_GeographyFromText('SRID=4326;multipolygon(((25 15, 26 15, 27
> 15, 28 15, 29 15, 30 15, 31 15, 32 15, 33 15, 34 15, 35 15, 35 25, 34 25, 33
> 25, 32 25, 31 25, 30 25, 29 25, 28 25, 27 25, 26 25, 25 25, 25 15)))'));
> INSERT 0 1
> Now I run a query that should return both rows.
> =# select m1.mpid from multipolygon m1 where st_intersects(m1.multip
> ,'POLYGON((27 17, 28 17, 28 19, 27 19, 27 17))'::geography);
> mpid
> 1
> (1 row)
> =# select m1.mpid from multipolygon m1 where st_intersects((select multip
> from multipolygon m2 where m2.mpid = m1.mpid ),'POLYGON((27 17, 28 17, 28
> 19, 27 19, 27 17))'::geography );
> mpid
> 1
> 2
> (2 rows)
> You can see the two queries seem to be logically the same but they return
> different results
> Next I will look at the plans for the two queries
> =# explain select m1.mpid from multipolygon m1 where st_intersects(m1.multip
> QUERY PLAN
> Seq Scan on multipolygon m1 (cost=0.00..317.40 rows=77 width=8)
> Filter: ((multip &&
> '0103000020E610000001000000050000000000000000003B4000000000000031400000000000003C4000000000000031400000000000003C4000000000000033400000000000003B4000000000000033400000000000003B400000000000003140'::geography)
> AND (_st_distance(multip,
> '0103000020E610000001000000050000000000000000003B4000000000000031400000000000003C4000000000000031400000000000003C4000000000000033400000000000003B4000000000000033400000000000003B400000000000003140'::geography,
> 0::double precision, false) < 1e-05::double precision))
> (2 rows)
> =# explain select m1.mpid from multipolygon m1 where st_intersects((select
> multip from multipolygon m2 where m2.mpid = m1.mpid ),'POLYGON((27 17, 28
> 17, 28 19, 27 19, 27 17))'::geography );
> QUERY PLAN
> Seq Scan on multipolygon m1 (cost=0.00..9788.80 rows=387 width=8)
> Filter: st_intersects((SubPlan 1),
> SubPlan 1
> -> Index Scan using pk_polygon on multipolygon m2 (cost=0.15..8.17
> rows=1 width=32)
> Index Cond: (mpid = m1.mpid)
> (5 rows)
> You can see that the query using _st_distance is the one that returns a bad
> result.
> However I can also show _st_distance() works if it is limited to finding
> just one
> result. Here is the same query that didn’t work, however this time I add a
> constraint
> to limit the result set to one row.
> ,'POLYGON((27 17, 28 17, 28 19, 27 19, 27 17))'::geography) and m1.mpid = 1;
> mpid
> 1
> (1 row)
> ,'POLYGON((27 17, 28 17, 28 19, 27 19, 27 17))'::geography) and m1.mpid = 2;
> mpid
> 2
> (1 row)
> QUERY PLAN
> Index Scan using pk_polygon on multipolygon m1 (cost=0.15..8.43 rows=1
> width=8)
> Index Cond: (mpid = 2)
> Filter: ((multip &&
> (3 rows)
> This might be the wrong conclusion but it appears that
> _st_distance() doesn’t work if the result set contains more
> than one row.
> Thanks in advance,
> Bob
> Robert Hartranft
> Mission Operations and Services
> Intelligence & Information System
> Raytheon Company
> 301-851-8197
> robert_m_hartranft at raytheon.com
> 5700 Rivertech Court
> Riverdale, MD 20737
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
