[postgis-users] PostGIS supported by which ArcGIS
Paolo Importuni
imppao at gmail.com
Fri Jan 16 00:01:44 PST 2015
Hi Adrian,
as far as I can remember there are two parameters in the table sde
'db_tune' that must be set to the PG_GEOMETRY type. I remember having the
same problem some times ago, due to the fact that I had set only one
parameter to the right type.
Then, of course, you will have to delete your geometry type and re-import
it.
Let us know if you sort it out.
regards
paolo
2015-01-15 21:23 GMT+01:00 Adrian Term <adrian.term at gmail.com>:
> I have the following setup :
> ArcGIS 10.2.2 for Desktop Advanced
> ArcGIS 10.2.2 for Server
> QGIS 2.6.1 Brighton
> PostgreSQL 9.2.9-3
> PostGIS 2.1
> I managed to make them all hear each other following this instructions :
> http://resources.arcgis.com/en/help/main/10.2/index.html#//002p000000t4000000
> Data is loaded from ArcGIS with the "Import feature class (single)"
> with the "PG_Geometry" configuration keyword in Geodatabase Settings.
> With ArcGIS I can connect, view, edit and save the data stored in the
> "esrified" PostgreSQL/PostGIS database tables.
> Unfortunately, when I try to do the same thing in QGIS i get an error
> message :
> "Errors: ERROR: 1 feature(s) not added.
> Provider errors:
> PostGIS error while adding features: ERROR: column "shape" is of type
> geometry but expression is of type st_geometry"
> On the other hand, I tried to do the same thing with UDIG and everything
> works perfect.
> I assume that the issue in QGIS is something about what Birgit mentioned :
> "If ArcGIS writes geometries into the PostgreSQL database it names the
> geometry column as "shape" with the datatype "geometry"
> Any ideas ?
> Adrian
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150116/08ef56e4/attachment.html>
