[postgis-users] Checking Road Network Topology
toni hernández
toni at sigte.udg.edu
Thu Jan 22 07:13:44 PST 2015
Steve,
I had the same issue when working with geometries using srid=4326 . I
was also following the same link
(http://blog.mathieu-leplatre.info/use-postgis-topologies-to-clean-up-road-networks.html)
Then I tried with some projected geometries (units = meters) and the
problem was gone. I am not sure why. Maybe it was just a coincidence.
cheers.
On 20/01/2015 20:45, Miller, Stephan wrote:
> All –
> I am attempting to validate the topology of a dense road network ( 1.2
> Million roads) modeled after
> from July 2013
> <http://blog.mathieu-leplatre.info/use-postgis-topologies-to-clean-up-road-networks.html%20from%20July%202013>.
> The code is given below:
> -- HC_RoadTopologicalCheck
> -- Drop the existing topology
> SELECT topology.DropTopology('roads_topo');
> SELECT topology.CreateTopology('roads_topo',4326, 0.000001, true);
> SELECT topology.AddTopoGeometryColumn('roads_topo', 'fgcm',
> 'transportationgroundcrv', 'topo_shape', 'LINESTRING');
> --UPDATE transportationgroundcrv SET topo_shape =
> topology.toTopoGeom(transportationgroundcrv.shape, 'roads_topo', 1, 1.0);
> -- Encapsulate the UPDATE inside code that checks for errors
> DO $$ DECLARE r record;
> BEGIN
> FOR r IN SELECT * FROM transportationgroundcrv loop
> BEGIN
> WHERE r.objectid = r.objectid;
> EXCEPTION
> WHEN OTHERS THEN
> RAISE WARNING 'Loading of record % failed: %',
> r.objectid, SQLERRM;
> END;
> END LOOP;
> END$$;
> Select * from ValidateTopology('roads_topo');
> I am getting everything passing to the exception statement and all the
> records are being flagged with
> WARNING: Loading of record 791456 failed: SQL/MM Spatial exception -
> curve not simple
> Intermittently, I am getting the following error also.
> WARNING: Loading of record 792591 failed: Spatial exception -
> geometry intersects edge 69612
> Everything appears to be flagged as an error; the ValidateTopology
> call returns nothing.
> Any insights or suggestions would be appreciated.
> Steve
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150122/46c8fd0b/attachment.html>
