[postgis-users] Checking Road Network Topology
Miller, Stephan
smille12 at harris.com
Thu Jan 22 07:35:42 PST 2015
Thanks.
Here is the code as it now stands. I was using 4326 and topology will not work for geography coordinates. Can you share your code so that I can compare? I am trying to do an on-the-fly transform to 32648 for each record in the line 26. Is that how you approached this problem?
Thanks,
Steve
[cid:image001.png at 01D0362C.CE47B050]
From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of toni hernández
Sent: Thursday, January 22, 2015 10:14 AM
To: postgis-users at lists.osgeo.org
Subject: Re: [postgis-users] Checking Road Network Topology
Steve,
I had the same issue when working with geometries using srid=4326 . I was also following the same link (http://blog.mathieu-leplatre.info/use-postgis-topologies-to-clean-up-road-networks.html)
Then I tried with some projected geometries (units = meters) and the problem was gone. I am not sure why. Maybe it was just a coincidence.
cheers.
On 20/01/2015 20:45, Miller, Stephan wrote:
All -
I am attempting to validate the topology of a dense road network ( 1.2 Million roads) modeled after http://blog.mathieu-leplatre.info/use-postgis-topologies-to-clean-up-road-networks.html from July 2013<http://blog.mathieu-leplatre.info/use-postgis-topologies-to-clean-up-road-networks.html%20from%20July%202013>. The code is given below:
-- HC_RoadTopologicalCheck
-- Drop the existing topology
SELECT topology.DropTopology('roads_topo');
SELECT topology.CreateTopology('roads_topo',4326, 0.000001, true);
SELECT topology.AddTopoGeometryColumn('roads_topo', 'fgcm', 'transportationgroundcrv', 'topo_shape', 'LINESTRING');
--UPDATE transportationgroundcrv SET topo_shape = topology.toTopoGeom(transportationgroundcrv.shape, 'roads_topo', 1, 1.0);
-- Encapsulate the UPDATE inside code that checks for errors
DO $$ DECLARE r record;
BEGIN
FOR r IN SELECT * FROM transportationgroundcrv loop
BEGIN
WHERE r.objectid = r.objectid;
EXCEPTION
WHEN OTHERS THEN
RAISE WARNING 'Loading of record % failed: %', r.objectid, SQLERRM;
END;
END LOOP;
END$$;
Select * from ValidateTopology('roads_topo');
I am getting everything passing to the exception statement and all the records are being flagged with
WARNING: Loading of record 791456 failed: SQL/MM Spatial exception - curve not simple
Intermittently, I am getting the following error also.
WARNING: Loading of record 792591 failed: Spatial exception - geometry intersects edge 69612
Everything appears to be flagged as an error; the ValidateTopology call returns nothing.
Any insights or suggestions would be appreciated.
Steve
postgis-users mailing list
postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150122/2e7d95b1/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150122/2e7d95b1/attachment.png>
