[postgis-users] Evenly distributing a point set
Mark Wynter
mark at dimensionaledge.com
Sun Jan 25 20:04:54 PST 2015
> These points were created from a GPX file along a road journey so they crudely map to a line string
"Map matching" is the term often used to describe the process of assigning noisy Gpx points to underlying road network.
> I was thinking compute the KNN distance for each point and remove those that have a KNN < a threshold (say 100 metres)
Not sure what your data is like-
Perhaps look at st_linesubstring where you can use generate series to produce a sequence of relative positions
> Is that the best way to go about it?**************
You may need to explore different methods - a method that works with your training dataset may not work so great on other Gpx datasets that were collected under different conditions
