[postgis-users] Get parallel some route.
Rémi Cura
remi.cura at gmail.com
Wed Jan 28 03:32:24 PST 2015
Same,
On peut répondre à la question en français,
il y en a quelques un sur la mailing list...
Rémi-C
2015-01-28 11:44 GMT+01:00 Nicolas Ribot <nicolas.ribot at gmail.com>:
> Hi Guillaume,
> Not sure I understand what you want to achieve.
> Can you describe it, maybe with an image. (or in french)
> Non-simple lines can be cut at their intersection to make them simple.
> Nicolas
> On 28 January 2015 at 09:16, Guillaume ARNAUD <guillaume.arnaud at cg82.fr>
> wrote:
>> Hello,
>> We use Postgre / Postgis database with ArcGIS Server and Desktop 10.2.
>> All our data are inserted with keyword Postgis into our database.
>> The table that has the trouble is a route table with 292 linestring. I
>> need these routes is not bunk. I try to use ST_OffsetCurve function to do
>> this. I found on the help and on a ticket that we must have geometry which
>> is simple. More than 250 isn't. Is there any solution to fix the problem or
>> to bypass the problem .
>> Thanks for your work.
>> Greating.
>> ARNAUD Guillaume
>> Sorry for my poor english, I'm french.
>> "PostgreSQL 9.2.2, compiled by Visual C++ build 1600, 64-bit
>> POSTGIS="2.0.4" GEOS="3.4.2-CAPI-1.8.2 r0" PROJ="Rel. 4.8.0, 6 March
>> 2012" GDAL="GDAL 1.10.0, released 2013/04/24" LIBXML="2.7.8"
>> LIBJSON="UNKNOWN" (core procs from "2.0.4" need upgrade) RASTER (raster
>> procs from "2.0.4" need upgrade)"
>> OS : Windows Server Standard SP 2
>> Guillaume ARNAUD
>> Cellule SIGD
>> Direction de l'Informatique
>> Conseil Général de Tarn-et-Garonne
>> 05-63-91-82-37
>> En interne, utilisez le Click To Call : 8237
>> <https://10.200.3.1:8443/webdialer/Webdialer?destination=8237>
>> [image: test] <http://www.carto.cg82.fr/>
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150128/3c41ec3c/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150128/3c41ec3c/attachment.jpg>
