[postgis-users] ST_BandPath() returns null or ô on out-db raster
Tumasgiu Rossini
rossini.t at gmail.com
Thu Jan 29 04:42:47 PST 2015
Hi List,
I am experiencing a problem with outdb geotiff importation.
I am using the raster2pgsql utility :
raster2pgsql -R -a -F \\fileserver\raster\419\napoleonien\*.tif catalog
On a particular set of geotiff ( wich are generated with the same routine
as the others ), the command seems to work fine
but St_BandPath() output null when I'm trying to register the tiffs on a
local server, and it output the character 'ô' on the production server.
On others set of raster, the band path is correctly stored.
What am I doing wrong ?
My configuration is the following :
Both Local and server ->
PostgreSQL 9.3.5 installed with EntrepriseDB
Postgis "2.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"
Win 7 64bit
"French_France.1252"
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150129/b8791609/attachment.html>
