[postgis-users] ST_BandPath() returns null or ô on out-db raster
Tumasgiu Rossini
rossini.t at gmail.com
Thu Jan 29 04:48:01 PST 2015
Sorry, a misclick sent the message before I had finished it :
St_BandPath() doesn't ouputs null but the emtpy string.
2015-01-29 13:42 GMT+01:00 Tumasgiu Rossini <rossini.t at gmail.com>:
> Hi List,
> I am experiencing a problem with outdb geotiff importation.
> I am using the raster2pgsql utility :
> raster2pgsql -R -a -F \\fileserver\raster\419\napoleonien\*.tif catalog
> On a particular set of geotiff ( wich are generated with the same routine
> as the others ), the command seems to work fine
> but St_BandPath() output null when I'm trying to register the tiffs on a
> local server, and it output the character 'ô' on the production server.
> On others set of raster, the band path is correctly stored.
> What am I doing wrong ?
> My configuration is the following :
> Both Local and server ->
> PostgreSQL 9.3.5 installed with EntrepriseDB
> Postgis "2.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"
> Win 7 64bit
> "French_France.1252"
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150129/4b516c23/attachment.html>
