[postgis-users] ST_BandPath() returns null or ô on out-db raster
Bborie Park
dustymugs at gmail.com
Thu Jan 29 06:45:54 PST 2015
I'm not aware that loading out-db rasters using Windows network path names
will work. What happens if you add that network path as a network drive?
Can you try something like the following? All I've done is replace the
backslash with a forward slash...
raster2pgsql -R -a -F \\\\fileserver/raster/419/napoleonien/*.tif catalog
I'm wondering if some escaping rules are getting in the way.
On Thu, Jan 29, 2015 at 4:42 AM, Tumasgiu Rossini <rossini.t at gmail.com>
wrote:
> Hi List,
> I am experiencing a problem with outdb geotiff importation.
> I am using the raster2pgsql utility :
> raster2pgsql -R -a -F \\fileserver\raster\419\napoleonien\*.tif catalog
> On a particular set of geotiff ( wich are generated with the same routine
> as the others ), the command seems to work fine
> but St_BandPath() output null when I'm trying to register the tiffs on a
> local server, and it output the character 'ô' on the production server.
> On others set of raster, the band path is correctly stored.
> What am I doing wrong ?
> My configuration is the following :
> Both Local and server ->
> PostgreSQL 9.3.5 installed with EntrepriseDB
> Postgis "2.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"
> Win 7 64bit
> "French_France.1252"
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150129/4288e2b2/attachment.html>
