[postgis-users] ST_BandPath() returns null or ô on out-db raster
Tumasgiu Rossini rossini.t at gmail.com
Thu Jan 29 07:35:00 PST 2015
Hi BBorie,
Out-db rasters referenced with network path do register on postgis tables !
I use it every day.
It was, like you suggested it, an escaping issue :
I have tried the command
raster2pgsql -R -a -F  \\serveur-ad/\raster/\419/\napoleonien/\*.tif
testraster  | psql -U postgres -p 5434 test
and it works. Thanks for the hint !
It is the '\419' part wich causes troubles, I renamed the directory and it
worked with the non-escaped. I think it is because the directory is only
made of numbers.
raster2pgsql might interpret \419 as a single character or something like
that.
2015-01-29 15:45 GMT+01:00 Bborie Park <dustymugs at gmail.com>:
> I'm not aware that loading out-db rasters using Windows network path names
> will work. What happens if you add that network path as a network drive?
> Can you try something like the following? All I've done is replace the
> backslash with a forward slash...
> raster2pgsql -R -a -F  \\\\fileserver/raster/419/napoleonien/*.tif catalog
> I'm wondering if some escaping rules are getting in the way.
> On Thu, Jan 29, 2015 at 4:42 AM, Tumasgiu Rossini <rossini.t at gmail.com>
> wrote:
>> Hi List,
>> I am experiencing a problem with outdb geotiff importation.
>> I am using the raster2pgsql utility :
>> raster2pgsql -R -a -F  \\fileserver\raster\419\napoleonien\*.tif catalog
>> On a particular set of geotiff ( wich are generated with the same routine
>> as the others ), the command seems to work fine
>> but St_BandPath() output null when I'm trying to register the tiffs on a
>> local server, and it output the character  'ô' on the production server.
>> On others set of raster, the band path is correctly stored.
>> What am I doing wrong ?
>> My configuration is the following :
>> Both Local and server ->
>>    PostgreSQL 9.3.5 installed with EntrepriseDB
>>    Postgis "2.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"
>>    Win 7 64bit
>> "French_France.1252"
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150129/445e111a/attachment.html>
