[postgis-users] Problem in Clip between geometry and raster table
Marcello Benigno
benigno.marcello at gmail.com
Wed Jul 1 04:12:17 PDT 2015
Hello guys,
When attempting to perform a clip from a polygon and a raster table , the
following error appeared:
ERROR: column "nan" does not exist
> LINE 1: SELECT (NaN)::double precision
> QUERY: SELECT (NaN)::double precision
> CONTEXT: PL/pgSQL function st_clip(raster,integer,geometry,double
> precision[],boolean) line 42 at assignment
> SQL function "st_clip" statement 1
> (execution time: 250 ms; total time: 485 ms)
> SELECT (ST_DumpAsPolygons(ST_Clip(c.geom, ST_Buffer(f.geometria, 0.01),
> TRUE))).val AS dn,
> TRUE))).geom AS geom
> FROM public.propriedade_geometria f, dados.edr c
> WHERE ST_Intersects(f.geometria, c.geom)
> AND f.tipo = 2 AND f.propriedade_id = 6063 AND c.id_uf = 2 AND c.cidade_id
> = 4681;
I can't understand what may be happening. Can I perform a casting to solve
this problem ?
*Marcello Benigno B. de Barros Filho*
Prof. do Curso Superior de Tecnologia em Geoprocessamento - IFPB
Mestre em Ciências Geodésicas e Tecnologias da Geoinformação - UFPE
Doutorando em Tecnologia Ambiental e Recursos Hídricos - UFPE
http://profmarcello.blogspot.com
http://about.me/marcello.benigno
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150701/f8996e3a/attachment.html>
