[postgis-users] raster, stats conditioned to a set of values
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Mon Jul 6 07:12:11 PDT 2015
These are not error. Only notices. Are you sure the query returned nothing?
Otherwise I would restart with something more simple to double check some prerequired things.
1) Make sure your two raster table actually contains pixels with values
2) Make sure some tiles actually intersects
Do you have a way to display the footprints of your rasters tiles?
Pierre
> -----Original Message-----
> From: juli g. pausas [mailto:juli.g.pausas at uv.es]
> Sent: Monday, July 06, 2015 9:58 AM
> To: Pierre Racine
> Cc: PostGIS Users Discussion
> Subject: Re: [postgis-users] raster, stats conditioned to a set of values
> INSERT INTO rastertmp.provanet
>     SELECT t1.rid, ST_Union(ST_Intersection(t1.rast, 1, t2.rast, 1, 'BAND1'))
>     FROM rastertmp.prova AS t1, rastertmp.provapositiu AS t2
>     WHERE ST_Intersects(t1.rast, t2.rast)
>     GROUP BY t1.rid;
> NOTICE:  The two rasters provided have no intersection.  Returning no band
> raster
> CONTEXT:  PL/pgSQL function
> st_intersection(raster,integer,raster,integer,text,double precision[]) line 20
> at assignment
> NOTICE:  Could not find raster band of index 1 when setting pixel value.
> Nodata value not set. Returning original raster
> Juli
> CIDE, CSIC  |  www.uv.es/jgpausas  |
> On Mon, Jul 6, 2015 at 3:52 PM, Pierre Racine
> <Pierre.Racine at sbf.ulaval.ca> wrote:
> 	> Adding a GROUP BY t1.rid, doesn't solve the problem, still get an
> error.
> 	Which error?
