[postgis-users] 2.1.8 Bug Fix Release
Greg Troxel
gdt at ir.bbn.com
Tue Jul 7 15:46:18 PDT 2015
Sandro Santilli <strk at keybit.net> writes:
>> +share/postgresql/extension/postgis--${PKGVERSION}--${PKGVERSION}.sql
> The ${PKGVERSION}--${PKGVERSION} looks like a bug to me, but we don't
> do that ${PKGVERSION} ourselves, right ? So you should tell more about
> how you generate them.
Sorry, I was sending you a diff from our packing list (PLIST) file,
which is generated to replace the version with $PKGVERSION to make it
more likely not to need to be updated later. I should have just shown
a directory listing of what was installed:
-rw-r--r-- 1 root wheel 569640 Jul 7 12:08 /usr/pkg/share/postgresql/extension/postgis--2.0.0--2.1.8.sql
-rw-r--r-- 1 root wheel 569640 Jul 7 12:07 /usr/pkg/share/postgresql/extension/postgis--2.0.1--2.1.8.sql
-rw-r--r-- 1 root wheel 569640 Jul 7 12:08 /usr/pkg/share/postgresql/extension/postgis--2.0.2--2.1.8.sql
-rw-r--r-- 1 root wheel 569640 Jul 7 12:07 /usr/pkg/share/postgresql/extension/postgis--2.0.3--2.1.8.sql
-rw-r--r-- 1 root wheel 569640 Jul 7 12:07 /usr/pkg/share/postgresql/extension/postgis--2.0.4--2.1.8.sql
-rw-r--r-- 1 root wheel 569640 Jul 7 12:08 /usr/pkg/share/postgresql/extension/postgis--2.0.5--2.1.8.sql
-rw-r--r-- 1 root wheel 569640 Jul 7 12:08 /usr/pkg/share/postgresql/extension/postgis--2.0.6--2.1.8.sql
-rw-r--r-- 1 root wheel 569640 Jul 7 12:07 /usr/pkg/share/postgresql/extension/postgis--2.0.7--2.1.8.sql
-rw-r--r-- 1 root wheel 535560 Jul 7 12:08 /usr/pkg/share/postgresql/extension/postgis--2.1.0--2.1.8.sql
-rw-r--r-- 1 root wheel 535560 Jul 7 12:08 /usr/pkg/share/postgresql/extension/postgis--2.1.0rc1--2.1.8.sql
-rw-r--r-- 1 root wheel 535560 Jul 7 12:08 /usr/pkg/share/postgresql/extension/postgis--2.1.0rc2--2.1.8.sql
-rw-r--r-- 1 root wheel 535560 Jul 7 12:08 /usr/pkg/share/postgresql/extension/postgis--2.1.0rc3--2.1.8.sql
-rw-r--r-- 1 root wheel 535560 Jul 7 12:08 /usr/pkg/share/postgresql/extension/postgis--2.1.1--2.1.8.sql
-rw-r--r-- 1 root wheel 535560 Jul 7 12:07 /usr/pkg/share/postgresql/extension/postgis--2.1.2--2.1.8.sql
-rw-r--r-- 1 root wheel 535560 Jul 7 12:07 /usr/pkg/share/postgresql/extension/postgis--2.1.3--2.1.8.sql
-rw-r--r-- 1 root wheel 535560 Jul 7 12:08 /usr/pkg/share/postgresql/extension/postgis--2.1.4--2.1.8.sql
-rw-r--r-- 1 root wheel 535560 Jul 7 12:08 /usr/pkg/share/postgresql/extension/postgis--2.1.5--2.1.8.sql
-rw-r--r-- 1 root wheel 535560 Jul 7 12:08 /usr/pkg/share/postgresql/extension/postgis--2.1.6--2.1.8.sql
-rw-r--r-- 1 root wheel 535560 Jul 7 12:08 /usr/pkg/share/postgresql/extension/postgis--2.1.7--2.1.8.sql
-rw-r--r-- 1 root wheel 535560 Jul 7 12:08 /usr/pkg/share/postgresql/extension/postgis--2.1.8--2.1.8.sql
-rw-r--r-- 1 root wheel 535560 Jul 7 12:07 /usr/pkg/share/postgresql/extension/postgis--2.1.8--2.1.8next.sql
-rw-r--r-- 1 root wheel 4216284 Jul 7 12:08 /usr/pkg/share/postgresql/extension/postgis--2.1.8.sql
-rw-r--r-- 1 root wheel 535560 Jul 7 12:08 /usr/pkg/share/postgresql/extension/postgis--2.1.8next--2.1.8.sql
-rw-r--r-- 1 root wheel 93820 Jul 7 12:08 /usr/pkg/share/postgresql/extension/postgis--unpackaged--2.1.8.sql
It was the 2.1.8-2.1.8 that appeared this release; there was no
2.1.7-2.1.7 before.
> The "next" files serve the purpose of doing upgrades between revisions
> advertising as the same version (2.1.8dev -> 2.1.8devnext -> 2.1.8dev).
> They don't really make sense for a release, so maybe we should make
> the Makefiles aware of what is a release and what a dev version and behave
> differently based on that.
That makes some sense, but I don't see then about 2.1.8next -> 2.1.8,
unless that's a supported downgrade.
> A patch is welcome.
Fair enough; I am simply trying to report odd changes in the set of
installed files. I'll try to have a look.
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150707/5f2c3148/attachment.pgp>
