[postgis-users] Postgres 9.4 long query times/stalls
William Kyngesburye woklist at kyngchaos.com
Mon Jul 13 14:14:17 PDT 2015
Jeez I'm an idiot.
I was confusing my view with a materialized view.  After upgrading, when I saw the materialized view I thought it was a leftover experiment that didn't work (I recall having trouble setting that up) and trashed it.  I only remember using the dynamic view, but my memory can be flaky ;)
When switching between 9.3 and 9.4 to test the supposed slow speed in 9.4, I queried the materialized view in 9.3 and the normal view in 9.4.  And only created the normal view on the other computer I tested.  Looks like I'll be restoring the materialized view in 9.4.  And trashing the normal view so it doesn't confuse me in the future.
On Jul 13, 2015, at 3:14 PM, Paragon Corporation <lr at pcorp.us> wrote:
> You could turn logging on your database and see the query output in the log
> file.
> ALTER DATABASE mydb
>  SET log_statement = 'all';
> Hope that helps,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at lists.osgeo.org
> [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of William
> Kyngesburye
> Sent: Monday, July 13, 2015 3:54 PM
> To: PostGIS Users Discussion
> Cc: William Kyngesburye
> Subject: Re: [postgis-users] Postgres 9.4 long query times/stalls
> Yes, I vacuum analyzed.
> I don't have an explain - I'm running this from ogr2ogr.  I don't know how
> to do the ogr2ogr -spat in sql.
> On Jul 13, 2015, at 1:59 PM, Tom Kazimiers <tom at voodoo-arts.net> wrote:
>> Hi William,
>> Did you run VACUUM ANALYZE on on the PG 9.4 table (after you imported
>> the data)? This would be required to have up-to-date statistics which
>> the query planner uses to e.g. decide if using an index would improve
>> query time.
>> And what is the query plan for your query (EXPLAIN ANALYZE)?
>> Best,
>> Tom
>> On Mon, Jul 13, 2015 at 01:22:30PM -0500, William Kyngesburye wrote:
>>> I'm finally getting around to upgrading to Postgres 9.4 and I'm seeing
> long query times on my Postgis database.
>>> In Postgres 9.3.6, Postgis 2.1.7, I have a 70M record table of lines,
> with a view that does a complex lookup to another 67M record non-geo table.
> Extracting a small .2°x.2° area with ogr2ogr on the view takes less than a
> second (result about 1000 records).  The line table has indexes on all
> pertinent columns, while the non-geo lookup table has most columns indexed,
> except a couple used for sorting.
>>> Now in Postgres 9.4.4, Postgis 2.1.7, same tables, though I
>>> preselected the lines needed in the view so it's now 44M records (so
>>> I could drop the WHERE from the view), and I added the missing
>>> indexes needed for sorting to the lookup table.  So, more optimized.
>>> But, the same area query from ogr2ogr takes 3 minutes! (which is an
>>> improvement on the 4 min I got before I added the missing indexes)
>>> The Postgres process is constantly reading from the HD during the query.
>>> The same area query on the raw line table takes less than a second on
> both PG 9.3 and 9.4 (slightly quicker on 9.4 because it's preselected, fewer
> lines).
>>> I reimported all the data for the preselect optimization, so nothing
> should be corrupt from the upgrade.
>>> I did get the query down to a minute on another computer, but that's
> probably because it has a SSD drive (though slower processor).  Still MUCH
> slower that PG 9.3 on a HDD.
>>> Any ideas what's wrong?  It seems to me like the spatial indexes are not
> working so it has to look at all records.
>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>> http://www.kyngchaos.com/
>>> "History is an illusion caused by the passage of time, and time is an
> illusion caused by the passage of history."
>>> - Hitchhiker's Guide to the Galaxy
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> "This is a question about the past, is it? ... How can I tell that the past
> isn't a fiction designed to account for the discrepancy between my immediate
> physical sensations and my state of mind?"
> - The Ruler of the Universe
"The beast is actively interested only in now, and, as it is always now and always shall be, there is an eternity of time for the accomplishment of objects."
- the wisdom of Tarzan
