[postgis-users] Intersect ???
Eduardo Bieñkowski
edukoski at gmail.com
Thu Jul 30 18:20:53 PDT 2015
Thanks for your quick response.
I'll try and I'll think about for results
2015-07-30 16:28 GMT-03:00 Rémi Cura <remi.cura at gmail.com>:
> Hey,
> answered a few weeks ago :
> http://comments.gmane.org/gmane.comp.gis.postgis/38249
> Cheers
> Rémi-C
> 2015-07-30 18:30 GMT+02:00 Basques, Bob (CI-StPaul) <
> bob.basques at ci.stpaul.mn.us>:
>> I’ve done this with a SQL statement in the past. (it’s been a few years
>> now.)
>> It was dependent on the lines actually intersecting each other
>> (diagrammatic lifework) vs physical representations. We had to manually
>> end the line work at the intersections, and in some instances divide lines
>> that need a break at the intersections.
>> You can still do the intersection extract without all this work by using
>> a gap tolerance in the search, but this may lead to more errors depending
>> on number of short street segments, etc in the dataset.
>> Another way to approach this is by matching up street attributes like
>> names. You can then derive a street intersection name index for zooming-to
>> in a map. you’ll also likely need to use a self join of some type.
>> Lastly, you can use a straight tabular method, that uses a cartiesian
>> coordinate equation and check every line segment again every other (Hint:
>> a^2 + b^2 = c^2) You don’t even need POSTGIS for this is you have the end
>> points of each line segment as coordinates. In most cases this type of
>> search is very fast.
>> I would look at the ST_INTERSECTS and possibly ST_CROSSES functions to
>> start with, but they don’t actually give up a point.
>> Also, this may help get you started . . .
>> http://gis.stackexchange.com/questions/20835/identifying-road-intersections-using-postgis
>> bobb
>> On Jul 30, 2015, at 11:06 AM, Eduardo Bieñkowski <edukoski at gmail.com>
>> wrote:
>> I have one and only one layer lines (they are city streets)
>> How I can get a point layer where the lines cross? and so have a layer of
>> crosspoints
>> Apologize for my English
>> Eduardo
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Eduardo
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150730/21236e28/attachment.html>
