[postgis-users] creating topology data is slow
Marc-André Goderre
magoderre at cgq.qc.ca
Tue Jun 2 10:25:02 PDT 2015
Hello all,
I'm creating topology data from almost all world road OSM data ( More than 77 Million ways).
Processing the data with postgis topology in one shot is so long than that I created a hexagonal grid that let me create topological data from only one or many cell of the grid.
Even this way, It' s going to take many month to process the world's data.
Is there a way to make it faster?
This is my function that I use to process data.
CREATE OR REPLACE FUNCTION cm_update_tile_data(tile_id integer)
RETURNS character varying AS
$BODY$
DECLARE r RECORD;
BEGIN
FOR r IN SELECT * FROM way, join world_grid on line&& the_geom where gid=tile_id and topo_geom is NULL LOOP
BEGIN
UPDATE way
SET topo_geom = topology.toTopoGeom(st_force2d(line), 'way_topo', 1)
WHERE id = r.id;
EXCEPTION
WHEN OTHERS THEN
RAISE WARNING 'Loading of record % failed: %', r.id, SQLERRM;
END;
END LOOP;
UPDATE world_grid set last_update = now() where gid=tile_id;
return 'OK';
END
$BODY$
LANGUAGE plpgsql VOLATILE
COST 100;
Thanks
Marc
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150602/5409232e/attachment.html>
