[postgis-users] SQL vs. Extensions
Mike Toews mwtoews at gmail.com
Tue Jun 2 12:55:48 PDT 2015
Hi Andy
Perhaps legacy.sql was also enabled with the SQL technique? This would
have, for example, both ST_X() and X() functions. There is no
equivalent for legacy.sql for EXTENSION.
You might need to compare the functions on each installation to get a
good idea of the differences, e.g.
http://stackoverflow.com/q/1559008/327026
-Mike
On 2 June 2015 at 11:15, Yoder, Andrew (AYODER) <AYODER at arinc.com> wrote:
> Hello,
> I am a Postgres DBA, new to PostGIS, working at a company that uses PostGIS.
> I am building a new database using PostgreSQL 9.4 and PostGIS 2.1.
> My question:
> Previously the databases here have been built by installing the PostgreSQL
> and PostGIS packages, and then running the postgis.sql and
> spatial_ref_sys.sql scripts provided by the install.  I am experimenting
> with installing PostGIS via extensions only.  To test, I installed two
> databases using PostgreSQL 9.4, one the old way of installing the packages
> and running the scripts, and one with the packages and using the postgis,
> postgis_tiger_geocoder,  and postgis_topology extensions – both were into a
> newly created template_gis database.   The issue is I do not believe I have
> installed everything that needs to be installed.  Building the database
> using the first method yielded an install with 3258 functions owned by
> postgres user.  Using the extensions approach I have only 2685.  There may
> be more items missing – this is all I compared before searching for
> information on the internet.  From the extensions portion of the manual, it
> only mentioned using postgis and postgis_topology (with tiger geocoder
> appearing to be an “extra”).
> Please forgive the crude comparisons done.  Any input on what I am missing,
> or if the lesser number of functions is “normal” would be appreciated.
> Sincerely,
> Andy Yoder
