[postgis-users] creating topology data is slow
Marc-André Goderre
magoderre at cgq.qc.ca
Thu Jun 4 08:21:54 PDT 2015
Does the processing became slower when the edge_data table became bigger?
Marc
-----Message d'origine-----
De : postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] De la part de Lars Aksel Opsahl
Envoyé : 3 juin 2015 01:56
À : PostGIS Users Discussion
Objet : Re: [postgis-users] creating topology data is slow
We are working quite big datasets (about 1 billion points and 20 million lines) that we convert from simple feature to topology. I ran a test yesterday and we added these 20 million lines in about 9 hours with attached attributes. This means heavy parallel pressing and grid usage on a fast database, but we use the Postgis topology package mostly as it is (picked from trunk about a moth ago) .
We will give a talk about how we do this at foss4g 2015 in Como in July.
Lars
Fra: postgis-users-bounces at lists.osgeo.org [postgis-users-bounces at lists.osgeo.org] på vegne av Rémi Cura [remi.cura at gmail.com]
Sendt: 2. juni 2015 21:33
Til: PostGIS Users Discussion
Emne: Re: [postgis-users] creating topology data is slow
I'm working on a batch way to import topology, it is not ready yet.
If you now for sure your data is correct, you can skip a lot of testing and be efficient in a batch way.
You could use grass and the topological export.
Cheers,
Rémi-C
2015-06-02 19:25 GMT+02:00 Marc-André Goderre <magoderre at cgq.qc.ca<mailto:magoderre at cgq.qc.ca>>:
Hello all,
I'm creating topology data from almost all world road OSM data ( More than 77 Million ways).
Processing the data with postgis topology in one shot is so long than that I created a hexagonal grid that let me create topological data from only one or many cell of the grid.
Even this way, It' s going to take many month to process the world's data.
Is there a way to make it faster?
This is my function that I use to process data.
CREATE OR REPLACE FUNCTION cm_update_tile_data(tile_id integer)
RETURNS character varying AS
$BODY$
DECLARE r RECORD;
BEGIN
FOR r IN SELECT * FROM way, join world_grid on line&& the_geom where gid=tile_id and topo_geom is NULL LOOP
BEGIN
UPDATE way
SET topo_geom = topology.toTopoGeom(st_force2d(line), 'way_topo', 1)
WHERE id = r.id<http://r.id>;
EXCEPTION
WHEN OTHERS THEN
RAISE WARNING 'Loading of record % failed: %', r.id<http://r.id>, SQLERRM;
END;
END LOOP;
UPDATE world_grid set last_update = now() where gid=tile_id;
return 'OK';
END
$BODY$
LANGUAGE plpgsql VOLATILE
COST 100;
Thanks
Marc
postgis-users mailing list
postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
