[postgis-users] creating topology data is slow
Lars Aksel Opsahl
lop at skogoglandskap.no
Thu Jun 4 21:56:50 PDT 2015
Yes there is slow down but I am not ready with the numbers yet and we have not focused to much on that now, because to go from simple feature to topology is a one time job in our case.
Whats more important is the update time when we apply changes to a exiting layer after it's created and that also involves adding new lines so we have to look more into this later, but an update in our case also involves line attribute handling and surfaces and surface attributes.
I will have more numbers ready in July.
Lars
________________________________________
Fra: postgis-users-bounces at lists.osgeo.org [postgis-users-bounces at lists.osgeo.org] på vegne av Marc-André Goderre [magoderre at cgq.qc.ca]
Sendt: 4. juni 2015 17:21
Til: PostGIS Users Discussion
Emne: Re: [postgis-users] creating topology data is slow
Does the processing became slower when the edge_data table became bigger?
Marc
-----Message d'origine-----
De : postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] De la part de Lars Aksel Opsahl
Envoyé : 3 juin 2015 01:56
À : PostGIS Users Discussion
Objet : Re: [postgis-users] creating topology data is slow
We are working quite big datasets (about 1 billion points and 20 million lines) that we convert from simple feature to topology. I ran a test yesterday and we added these 20 million lines in about 9 hours with attached attributes. This means heavy parallel pressing and grid usage on a fast database, but we use the Postgis topology package mostly as it is (picked from trunk about a moth ago) .
We will give a talk about how we do this at foss4g 2015 in Como in July.
Lars
Fra: postgis-users-bounces at lists.osgeo.org [postgis-users-bounces at lists.osgeo.org] på vegne av Rémi Cura [remi.cura at gmail.com]
Sendt: 2. juni 2015 21:33
I'm working on a batch way to import topology, it is not ready yet.
If you now for sure your data is correct, you can skip a lot of testing and be efficient in a batch way.
You could use grass and the topological export.
Cheers,
Rémi-C
2015-06-02 19:25 GMT+02:00 Marc-André Goderre <magoderre at cgq.qc.ca<mailto:magoderre at cgq.qc.ca>>:
Hello all,
I'm creating topology data from almost all world road OSM data ( More than 77 Million ways).
Processing the data with postgis topology in one shot is so long than that I created a hexagonal grid that let me create topological data from only one or many cell of the grid.
Even this way, It' s going to take many month to process the world's data.
Is there a way to make it faster?
This is my function that I use to process data.
CREATE OR REPLACE FUNCTION cm_update_tile_data(tile_id integer)
RETURNS character varying AS
$BODY$
DECLARE r RECORD;
BEGIN
FOR r IN SELECT * FROM way, join world_grid on line&& the_geom where gid=tile_id and topo_geom is NULL LOOP
BEGIN
UPDATE way
SET topo_geom = topology.toTopoGeom(st_force2d(line), 'way_topo', 1)
WHERE id = r.id<http://r.id>;
EXCEPTION
WHEN OTHERS THEN
RAISE WARNING 'Loading of record % failed: %', r.id<http://r.id>, SQLERRM;
END;
END LOOP;
UPDATE world_grid set last_update = now() where gid=tile_id;
return 'OK';
END
$BODY$
LANGUAGE plpgsql VOLATILE
COST 100;
Thanks
Marc
postgis-users mailing list
postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
