[postgis-users] Get only the main river. Smoothline???
toni hernández toni at sigte.udg.edu
Mon Jun 8 23:09:07 PDT 2015
Thanks Remi,
I thought that but I have no starting/ending points. St_StartPoint and
St_EndPoint are not working with MultiLinestrings
I'll give it some more intense thought. :)
Cheers.
*Toni Hernández Vallès*
Servei de Sistemes d'Informació Geogràfica i Teledetecció
Universitat de Girona
*SIGTE*
Pl. Ferrater Mora 1
17071 Girona
Tel +34 972 418 039 (7026 intern)
toni at sigte.udg.edu <mailto:toni at sigte.udg.edu>
http://www.sigte.udg.edu
Twitter http://twitter.com/SIGTE_UDG
On 08/06/2015 17:45, Rémi Cura wrote:
> if you have start and end point of geom B,
> you can get the river path with a shortest path method (one liner
> using python, can be done in few hours using plpgsql).
> The idea is that you cut your geom into segments(pairs of points)
> , the length of the segment is the weight of this edge
> , and you know which segment is connected to which segment (adjacency
> graph).
> Then you use Networkx
> <http://networkx.lanl.gov/reference/generated/networkx.algorithms.shortest_paths.generic.shortest_path.html#networkx.algorithms.shortest_paths.generic.shortest_path>shortest
> path distance.
> Else,
> you are up to use some nasty workaround I suppose (playing with
> buffers on your original river surface, testing which segment
> intersects etc. ).
> I tried that but it ends up being more work (and more corner cases)
> than doing the things properly (in my experience).
> Cheers,
> Rémi-C
> 2015-06-08 16:42 GMT+02:00 toni hernández <toni at sigte.udg.edu
> <mailto:toni at sigte.udg.edu>>:
>     Hi everyone,
>     I have a multilinestring with a river and all its afluents as you
>     can see in this image
>     http://sigserver4.udg.edu/apps/geometries.png
>     I got geometry A using St_StraithSkeleton.
>     Is there a way to go from geometry A to geometry B??
>     Maybe something similar to SmoothLine???
>     *SIGTE*
>     Pl. Ferrater Mora 1
>     17071 Girona
>     _______________________________________________
>     postgis-users mailing list
>     postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
>     http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150609/832688c1/attachment.html>
