[postgis-users] Get only the main river. Smoothline???
toni hernández
toni at sigte.udg.edu
Mon Jun 8 23:51:24 PDT 2015
Remi,
I didn't tell you before but I want to use the main river line as the
line for labeling river's name. So an approximation to the main river is
good enough for me.
For a major number of cases (rivers tend to be quite linear), I can use
the st_longestline to get an approximation for the start/end points and
from there I can use the routing functions.
Thanks.
Cheers.
*Toni Hernández Vallès*
Servei de Sistemes d'Informació Geogràfica i Teledetecció
Universitat de Girona
*SIGTE*
Pl. Ferrater Mora 1
17071 Girona
Tel +34 972 418 039 (7026 intern)
toni at sigte.udg.edu <mailto:toni at sigte.udg.edu>
http://www.sigte.udg.edu
Twitter http://twitter.com/SIGTE_UDG
On 09/06/2015 08:09, toni hernández wrote:
> Thanks Remi,
> I thought that but I have no starting/ending points. St_StartPoint and
> St_EndPoint are not working with MultiLinestrings
> I'll give it some more intense thought. :)
> Cheers.
> *SIGTE*
> Pl. Ferrater Mora 1
> 17071 Girona
> On 08/06/2015 17:45, Rémi Cura wrote:
>> if you have start and end point of geom B,
>> you can get the river path with a shortest path method (one liner
>> using python, can be done in few hours using plpgsql).
>> The idea is that you cut your geom into segments(pairs of points)
>> , the length of the segment is the weight of this edge
>> , and you know which segment is connected to which segment (adjacency
>> graph).
>> Then you use Networkx
>> <http://networkx.lanl.gov/reference/generated/networkx.algorithms.shortest_paths.generic.shortest_path.html#networkx.algorithms.shortest_paths.generic.shortest_path>shortest
>> path distance.
>> Else,
>> you are up to use some nasty workaround I suppose (playing with
>> buffers on your original river surface, testing which segment
>> intersects etc. ).
>> I tried that but it ends up being more work (and more corner cases)
>> than doing the things properly (in my experience).
>> Cheers,
>> Rémi-C
>> 2015-06-08 16:42 GMT+02:00 toni hernández <toni at sigte.udg.edu
>> <mailto:toni at sigte.udg.edu>>:
>> Hi everyone,
>> I have a multilinestring with a river and all its afluents as you
>> can see in this image
>> http://sigserver4.udg.edu/apps/geometries.png
>> I got geometry A using St_StraithSkeleton.
>> Is there a way to go from geometry A to geometry B??
>> Maybe something similar to SmoothLine???
>> *SIGTE*
>> Pl. Ferrater Mora 1
>> 17071 Girona
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150609/6aad05ba/attachment.html>
