[postgis-users] Get only the main river. Smoothline???
Hugues François
hugues.francois at irstea.fr
Mon Jun 8 23:56:13 PDT 2015
Hello,
I think ST_Dump could help to deal with multilinestrings: http://postgis.net/docs/ST_Dump.html
Hugues.
De : postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] De la part de toni hernández
Envoyé : mardi 9 juin 2015 08:09
À : postgis-users at lists.osgeo.org
Objet : Re: [postgis-users] Get only the main river. Smoothline???
Thanks Remi,
I thought that but I have no starting/ending points. St_StartPoint and St_EndPoint are not working with MultiLinestrings
I'll give it some more intense thought. :)
Cheers.
Toni Hernández Vallès
Servei de Sistemes d'Informació Geogràfica i Teledetecció
Universitat de Girona
SIGTE
Pl. Ferrater Mora 1
17071 Girona
Tel +34 972 418 039 (7026 intern)
toni at sigte.udg.edu
http://www.sigte.udg.edu
Twitter http://twitter.com/SIGTE_UDG
On 08/06/2015 17:45, Rémi Cura wrote:
if you have start and end point of geom B,
you can get the river path with a shortest path method (one liner using python, can be done in few hours using plpgsql).
The idea is that you cut your geom into segments(pairs of points)
, the length of the segment is the weight of this edge
, and you know which segment is connected to which segment (adjacency graph).
Then you use Networkx <http://networkx.lanl.gov/reference/generated/networkx.algorithms.shortest_paths.generic.shortest_path.html#networkx.algorithms.shortest_paths.generic.shortest_path> shortest path distance.
Else,
you are up to use some nasty workaround I suppose (playing with buffers on your original river surface, testing which segment intersects etc. ).
I tried that but it ends up being more work (and more corner cases) than doing the things properly (in my experience).
Cheers,
Rémi-C
2015-06-08 16:42 GMT+02:00 toni hernández <toni at sigte.udg.edu>:
Hi everyone,
I have a multilinestring with a river and all its afluents as you can see in this image
http://sigserver4.udg.edu/apps/geometries.png
I got geometry A using St_StraithSkeleton.
Is there a way to go from geometry A to geometry B??
Maybe something similar to SmoothLine???
SIGTE
Pl. Ferrater Mora 1
17071 Girona
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150609/d4c02faf/attachment.html>
