[postgis-users] Expand odd shapes
Andy Colson andy at squeakycode.net
Tue Jun 9 16:29:53 PDT 2015
At first I thought no, because it creates a circle around a point:
"Returns a geometry that represents all points whose distance from this Geometry is less than or equal to distance"
But now that I read it again, maybe it does do what I'd like.  If I pass a rectangle, it'll return all points <= radius.
I'll give it a shot and try it out.  Thanks for the help.
-Andy
On 06/09/2015 04:48 PM, Basques, Bob (CI-StPaul) wrote:
> Can you use ST_Buffer??
> bobb
>> On Jun 9, 2015, at 4:34 PM, Andy Colson <andy at squeakycode.net> wrote:
>> Hi all.
>> I have buffer selection problem.  My site can drop a point, then find all the parcels within 100 feet of that point.  No problem.
>> One client however would like to select a parcel (maybe its a square, maybe its a triangle, or any other odd shape), and find all other parcels within 100 feet of any point within the source parcel.
>> 100 is optional.  They could choose 50, or 150.
>> I'm not sure how to do something like this.  I found ST_Expand, but that'll create a bounding box around the triangle.
>> ST_TransScale could scale it, but I'm not sure what the scale is.  The user might type in 50 feet or 150 feet, I'm not sure how to calculate a deltaX and deltaY scale for that.
>> Any hints on how I might go about this?  I'm a bit stuck.
>> Thanks,
>> -Andy
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
